Question Add files
- karloshull
- Topic Author
- Junior Member
Switched to Aurelia, how do you disable bootstrap files?
If you use an htaccess with any adjustments, turn it off for a while by giving it a different name for a test whether it works.
And Rich also asked if you use eg plugin JCH Optimize if so also turn it off.
or take a look in your template to see if you see anything about Optimize and then turn it on or off and test
L.v.d.A
- karloshull
- Topic Author
- Junior Member
I disabled CSS & JS Optimization - ADD Files still not working.
Any more ideas?
it seems that somewhere or by a website security or setting the upload is blocked
you could try again to re-enter and save the kunena uploads setting one by one
L.v.d.A
- karloshull
- Topic Author
- Junior Member
I have created a new site to test if the button works
I copied all the kunena data from the sql database and then I insert it into the new database.
Then I instaled kunena on the new website
The add button works as file manager pop up, and clicked on a file
and I got this error
Failed to open upload input stream.
So how can I fix this error?
or folder permissions
check administrator > System Information whether with folder permissions everything is green except configuration.php
L.v.d.A
Have you also cleared the cache afterwards?I disabled "Load bootstrap css" (in the Aurelia setting) And the action button stopped working.
Any more ideas?
- karloshull
- Topic Author
- Junior Member
So I decided to start again with fresh new joomla installed and fresh new kunena installed without editing the database
And I got the same error
So it must be the server? If so, any ideas where to look?
I am using plesk
OS
Ubuntu 20.04.4 LTS
Product
Plesk Obsidian
Version 18.0.45 Update #2, last updated on Aug 2, 2022 11:18 AM
- karloshull
- Topic Author
- Junior Member
"The add button works as file manager pop up, and clicked on a file and I got this error Failed to open upload input stream."
on which file do you click that are on your PC/laptop. can it not be the security of your own pc/laptop which then blocks
you on the chosen pc/laptop folder.
Are other forum users experiencing this as well?
or then maybe something in the php settings.
do they match the minimum requirements stated here?
www.kunena.org/docs/en/basics/requirements/requirements-k6-0
and here I read something Check for open_basedir restrictions
bobcares.com/blog/joomla-there-was-an-er...-file-to-the-server/
L.v.d.A
