Question Avatar/Profile/Edit not working
4 years 8 months ago #222245 by Coss
"you are using the kunena Aqidah_ku template ?"  Yes.
Here's Crypsis3, it all appear to function -  but there's a lot of formatting to sort
Click on Profile
Click on Edit
Click on Avatar Image link at bottom
So it looks to be working but I'll have to figure out how to format it to look good.
4 years 8 months ago #222248 by Leen
yes it is really difficult to solve this with template helix.
and the Aqidah_Ku_Free_Kunena_Template.zip doesn't work for me either.
with cypris I succeed if I put the old bootstrap.min.js from earlier helix ulimate back in the folder
\templates\shaper_helixultimate\js\
but with cypers I have to turn off the settings tab advanced Loading of the Bootstrap css
I zipped up that old bootstrap.min.js so that I can post it here as an attachment so you can try it out.
With kind regards
Leen
4 years 8 months ago #222258 by Coss
Thank you for that, I will try as you suggest.
4 years 8 months ago #222260 by Coss
Unfortunately, no - that doesn't work for me.
I guess I will have to use the Aqidah-Ku for the formatting and walk the users through, changing the avatars/profile.
It's a shame that Crypsis and Helix Ultimate don't play well.
As my site is a non commercial, no money, site, I can tell the users, to live with, back end inconvenience.
I'll see if I can contact, the Aqidah-Ku dev and I'll report back if I achieve anything.
4 years 8 months ago #222261 by Coss
Actually, a quick try of Crypsisb4 is looking promising.
I will now abandon Aqidah-Ku
4 years 8 months ago #222265 by Coss
I note:
because of an error "Cannot use a stream transport when "allow_url_fopen" is disabled"
I have enabled "allow_url_fopen"
