Question Avatar/Profile/Edit not working
4 years 8 months ago #222234 by Coss
I've tried with the three Crypsis templates and another called Aquidah_ku - i can see the profile area, in various mismatched styles, the profile avatar/ edit, the log in and out,  are either absent or styled wrong.
If I log in to the Joomla side, I'm logged into the forum but none of the avatar/profile edit works. Is all of the logging in and out done via Joomla? and if so, I've probably not got the configuration in Kunena right, to make the avatar/profile/edit stuff work properly.
Attached are screen shots and configuration report.
Thanks in advance.
Attachment not found
Configuration report
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : shaper_helixultimate | author: | version: 2.0.7 | creationdate: Feb 2018
Kunena default template details : Aqidah_ku | author: JoomlaTema | version: 1.3 | creationdate: Sep 2021
Kunena template params:
Kunena version detailed: Kunena 5.2.8 | 2022-01-01 [ Alcora ]
Plugins: None
4 years 8 months ago #222238 by Leen
it looks like you are using the Helix Ultimate template in Joomla.
And it has the annoying property of not working on action buttons.
(See if necessary this topic is for the test version kunena version 6 but possibly also for 5.2.8
www.kunena.org/forum/k6-0-support-archiv...t-gives-error#222228 )
So try with the standard joomla template Beesz or Protostar first to see if it works.
ps
the attachment's screenshots there what went wrong is not visible.
With kind regards
Leen
4 years 8 months ago #222241 by Coss
Thanks, I renamed the file and the buttons started to - half - work, in that I got a pop up window on clicking the avatar but still cannot edit the avatar..
I'll try and post a before image and an after image, below.
Admin logged in
After file renamed but can't edit avatar
_____
4 years 8 months ago - 4 years 8 months ago #222242 by Coss
images didn't work in this one
Last edit: 4 years 8 months ago by Coss.
4 years 8 months ago - 4 years 8 months ago #222243 by Coss
I'll try again:::
Whoa!
So I renamed the     bootstrap dot bundle dot min dot js
And step by step, this what I got
Click on Profile Button
Click on Edit Button
Click on Avatar Image link, at right
There's nothing to see/do - So I just dragged an image, from my desktop, to the window and saved, the blank window.
Then I clicked  Profile
And I have a new avatar !  Very Good.
Please note, the broken style, of the small avatar and two down arrows,  next to/under the search button.
Last edit: 4 years 8 months ago by Coss. Reason: tidy format
4 years 8 months ago #222244 by Leen
you are using the kunena Aqidah_ku template ?
is it also if you use Crypsis or Crypsis3 ?
With kind regards
Leen
Time to create page: 0.166 seconds
