Question Missing / not visible textfield for topic
4 years 10 months ago #221561 by nettemor
Here is the new configuration:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 129M | Max file upload: 128M
Joomla default template details : jsn_time2_pro | author: JoomlaShine.com | version: 1.0.8 | creationdate: 08/24/2021
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.2.8 | creationdate: 2022-01-01
Kunena template params:
Kunena version detailed: Kunena 5.2.8 | 2022-01-01 [ Alcora ]
Plugins: None
Modules: Kunena Latest 5.2.2 | Kunena Stats 5.2.2 | Kunena Login 5.2.2 | Kunena Search 5.2.2
4 years 10 months ago #221566 by nettemor
I said that i use wappalyzer to see the bootstrap version, and that its set to 4.0.0-beta2
When i open the kunena template krypsisb3 it says that "Crypsisb3 template using Bootstrap 3 and LESS"
Check image.
4 years 10 months ago #221568 by nettemor
I think i found a solution.
In the kunena template the "editor to use" was set to CKeditor. When i changed this to BBcode it all changed. I now can see the textfield and the user can enter their disucssion text.
Thank you so much for helping me out, i really appreciate it.
4 years 10 months ago - 4 years 10 months ago #221572 by rich
The exclusion field is located at the bottom left of your image. If you hover over it, you should see what and how to enter it in the tooltips.
You can try it with /media/kunena/core/js/ckeditor.js
But test it first with compression completely disabled. Uncheck both the CSS and Jayascript checkboxes at Assets Optimization, save it, and then clear the Joomla and browser cache. After that, test your forum.
Last edit: 4 years 10 months ago by rich.
Time to create page: 0.156 seconds
