Question Missing / not visible textfield for topic
4 years 10 months ago #221534 by nettemor
I have set up a new forum but seens i cannot register anything.
I can only register name, topic and select an icon (which is not visible). There are no big textfield for the user to enter the text.
I have tried with both jce editor and the original joomla editor.
Any idea?
4 years 10 months ago #221537 by nettemor
I have included an image to display the situation. Also you can go to the site and select forum from the menu bar.
4 years 10 months ago #221538 by rich
Without information, it will be difficult to help. Please create a  Configuration Report
The following user(s) said Thank You: nettemor
4 years 10 months ago #221539 by nettemor
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 129M | Max file upload: 128M
Joomla default template details : jsn_time2_pro | author: | version: 1.0.8 | creationdate: 08/24/2021
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.2.8 | creationdate: 2022-01-01
Kunena template params:
Kunena version detailed: Kunena 5.2.8 | 2022-01-01 [ Alcora ]
Plugins: None
Modules: Kunena Latest 5.2.2 | Kunena Stats 5.2.2 | Kunena Login 5.2.2 | Kunena Search 5.2.2
4 years 10 months ago #221541 by rich
Which bootstrap does your Joomla template use?
Check in the Joomla template settings the page compressions (CSS and scripts) and exclude Kunena from them:
Then fix these menu items in the main menu (see picture).
You can find out how to do it correctly here:
docs.kunena.org/en/troubleshooting/menu-issues
docs.kunena.org/en/faq/kunena-menu
4 years 10 months ago #221560 by nettemor
Hi Rich, thank you so much for getting back to me. I am kinda lost here /media/kunena/emoticons/
Seems i am using jquery 1.12.4 and bootstrap 4.0.0-beta2. I have no idea how this has been implemented, i have just updated template as new version has come along. And i just used wappalyzer to check the site configurations.
I have fixed the menus as you described, thank you for that. This should no be in order.
I am not sure what to and where to put the exclusion you talk about. I have added two images in this post. One image is template settings where i can probably write an exclusion? But what do i write?
Also added an image showing which template i am using.
Really appreciate you helping me out here, thank you so much.
Time to create page: 0.164 seconds
