Question BUG! - Registered users can post in blocked topic
7 years 6 months ago #210212 by rich
tomsson wrote:
810 wrote: Is the user the author of the topic?
no, but the same IP
The same IP does not matter.
Seems like registered users thet got moderator or < permissions.
I have chcecked on two different users with are not moderator and they have just registered permissions.
Yes, you see it, when the users would have moderator rights, they would to have the moderator buttons too.
If you lock a topic, shows this topic the padlock symbol? Empty the cache after you locked a topic and test it again.
7 years 6 months ago - 7 years 6 months ago #210218 by tomsson
Slacker wrote: In Kunena Administration you can choose Tools. Then Diagnostics where you can fix errors detected.
yes, there was 6 errors in attachmentOrphaned. I fixed. Celar the cache but the problem exist.
Yes, locked topic have padlock symbol. This is correct. The guest can not post anymore, but registered user stil can post, and seem like registered users have moderator perrmision, even they are just registered. They have moderator buttons and options aviable. This is what I do not understand.
I have double checked the perrmision for users in Joomla core users komponent -> registered, in community builder user are just registered, in kunena component the users have moderator option as deactived.
Last edit: 7 years 6 months ago by tomsson.
7 years 6 months ago #210219 by rich
It is not possible to register as a moderator, but with a wrong Joomla setting, you can e.g. register as administrator.
Please go in the backend to Kunena -> Users and create a screenshot (but paint over the email addresses).
7 years 6 months ago #210220 by tomsson
Here screenshot
7 years 6 months ago - 7 years 6 months ago #210221 by tomsson
I registered a new user on the front-end and logg inn, and after i go to the locked topic. Is the same - moderator option aviable.
In Joomla core I have set allow register new users, and registered as default group
EDIT
If i do chenge user group from registered to guest and refresh website then user do not see moderator option. hen is ok.
But if i do chenge group for the user from guest to registered and refresh the website then is the problem again.
Seems like the problem with perrmision.
I will try to disable some extra extensions.
7 years 6 months ago - 7 years 6 months ago #210223 by tomsson
tomsson wrote: Here screenshot
on this screen if I want to turn on moderator option with using this red cross in the column ''moderator'' then website is reloaded but can not turn on this option (moderator). I clic many times. Just reload website and all the time is red cross.
Time to create page: 0.171 seconds
