Question BUG! - Registered users can post in blocked topic
7 years 6 months ago #210172 by tomsson
Hi.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 128M
Joomla default template details : shaper_helixultimate | author: JoomShaper.com | version: 1.0.5 | creationdate: Feb 2018
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.12.1 | creationdate: 2019-04-22
Kunena template params:
Kunena version detailed: Kunena 5.1.12.1 | 2019-04-22 [ Kerberos ]
Third-party components: CommunityBuilder 2.4.1
Plugins: Search - Kunena Search 5.1.1
Modules: Kunena Latest 5.1.1
I have blocked one topic in my forum. I did it as administrator
after I logged inn as other user - registereg and I see that I can edit and answer for the topis with is blocked.
Seems like registered users thet got moderator or < permissions.
I have chcecked on two different users with are not moderator and they have just registered permissions.
Can you check it?
7 years 6 months ago #210176 by 810
Is the user the author of the topic?
7 years 6 months ago #210182 by rich
I've tried it with the same setting as in the configuration report, but can't reproduce this issue. I've created a locked toppic for you:
www.kunena.org/forum/163-Feature-Playground/158383-locked-topic
Is it possible for you to write an answer?
7 years 6 months ago - 7 years 6 months ago #210184 by tomsson
810 wrote: Is the user the author of the topic?
no, but the same IP
Last edit: 7 years 6 months ago by tomsson.
7 years 6 months ago #210185 by tomsson
rich wrote: I've tried it with the same setting as in the configuration report, but can't reproduce this issue. I've created a locked toppic for you:
Hi, thx , The toppic is locked. But in my forum the problem exist :)
7 years 6 months ago #210196 by Slacker
In Kunena Administration you can choose Tools. Then Diagnostics where you can fix errors detected.
Time to create page: 0.155 seconds
