Question Recent Topics menue item behaviour
- Gamer Templates
- Senior Member
If that is enough for you like here (my site for testing): www.gamer-templates.com/forum/recent-topics.html tell me, then I write you a small instruction.
Great, I testet it on your site and that is exactly what I needGamer Templates wrote: If that is enough for you like here (my site for testing): www.gamer-templates.com/forum/recent-topics.html tell me, then I write you a small instruction.
- Gamer Templates
- Senior Member
- Go to Admin -> Menus -> YOUR KUNENA MENU -> and find your Recent Topics ID (NOTICE THIS ID)
- Then open Recent Topics -> click Save as Copy
- Then Joomla create a new Menu Item with the Name Recent Topics (2)
- Click on "Menu Item Type *" and change this to System Links -> URL (DO NOT CLOSE THIS SITE)
- Open your Kunena Forum in Frontend in a new Browser Tab and go to Recent Topics
- Now you click on Site 2 and again on Site 1 and you have your URL in Browser
For example: www.gamer-templates.com/ forum/recent-topics.html?start=0 - Go back to Backend and insert the URL in the Link * Field at Recent Topics (2)
for example: forum/recent-topics.html?start=0 - Set Status on the right site on Published and Save
- Go back to Kunena Forum and refresh your site. Now you see 2 Tabs of Recent Topics and check if Recent Topics (2) works
- [strike]Now go to your Template custom.css or a css which will not override after update and insert this:
(MY item-ID IS AN EXAMPLE! USE YOUR item-ID FROM STEP 1.):[/strike][strike].item-859 {
display: none !important;
}[/strike] - Go to Recent Topics -> open -> Link Typ -> Display in Menu -> NO -> save
- Go back to Kunena Forum and refresh your site. Now you see 1 Tabs of Recent Topics (2)
- Change Menu Title Recent Topics (2) to Recent Topics in Admin and that is all!
- Gamer Templates
- Senior Member
Sebi wrote: Thank you for your instructions. It works! The only drawback is that the new menue item is not marked as selected.
Gamer Templates wrote: Without changing the cookies it also works
If you absolutely want to have it that way. (only ACTIVE does not work)
That's what I said
Instead of custom.css you can also use: Go to Recent Topics -> open -> Link Typ -> Display in Menu -> NO
It is the best way to disable the menu item.
I forgot this option
Delete the css entry and use this way. I change the instruction: HERE
I tried your second suggestion and it works, too.
But if I click on the Forum > Recent Topics link after, for example, page 3 was selected it will allways get me to page 3.
That is clear because your changes only affect the menu button.
So I implement a redirect in .htaccess from /forum/recent to /forum/recent?start=0.
That works BUT now, if I am logged in and on the forum/recent page (redirected to forum/recent?start=0) I can't log out.
Otherwise, if I am logged out I can't log in.
I know this must be a Joomla issue but maybe someone who reads this can help me with this issue.
