Question Recent Topics menue item behaviour
7 years 3 months ago - 7 years 3 months ago #208388 by Gamer Templates
Without changing the cookies it also works :-) If you absolutely want to have it that way. (only ACTIVE does not work)
If that is enough for you like here (my site for testing): www.gamer-templates.com/forum/recent-topics.html tell me, then I write you a small instruction.
Last edit: 7 years 3 months ago by Gamer Templates.
7 years 3 months ago #208389 by Sebi
Gamer Templates wrote: If that is enough for you like here (my site for testing): www.gamer-templates.com/forum/recent-topics.html tell me, then I write you a small instruction.
Great, I testet it on your site and that is exactly what I need :) I would appreciate your instruction.
7 years 3 months ago - 7 years 3 months ago #208392 by Gamer Templates
OK do this:
  1. Go to Admin -> Menus -> YOUR KUNENA MENU -> and find your Recent Topics ID (NOTICE THIS ID)
  2. Then open Recent Topics -> click Save as Copy
  3. Then Joomla create a new Menu Item with the Name Recent Topics (2)
  4. Click on "Menu Item Type *" and change this to System Links -> URL (DO NOT CLOSE THIS SITE)
  5. Open your Kunena Forum in Frontend in a new Browser Tab and go to Recent Topics
  6. Now you click on Site 2 and again on Site 1 and you have your URL in Browser
    For example: www.gamer-templates.com/ forum/recent-topics.html?start=0
  7. Go back to Backend and insert the URL in the Link * Field at Recent Topics (2)
    for example: forum/recent-topics.html?start=0
  8. Set Status on the right site on Published and Save
  9. Go back to Kunena Forum and refresh your site. Now you see 2 Tabs of Recent Topics and check if Recent Topics (2) works
  10. [strike]Now go to your Template custom.css or a css which will not override after update and insert this:
    (MY item-ID IS AN EXAMPLE! USE YOUR item-ID FROM STEP 1.):[/strike]
    [strike].item-859 {
    display: none !important;
    }[/strike]
  11. Go to Recent Topics -> open -> Link Typ -> Display in Menu -> NO -> save
  12. Go back to Kunena Forum and refresh your site. Now you see 1 Tabs of Recent Topics (2)
  13. Change Menu Title Recent Topics (2) to Recent Topics in Admin and that is all!
7 years 3 months ago - 7 years 3 months ago #208410 by Sebi
Thank you for your instructions. It works! The only drawback is that the new menue item is not marked as selected.
Last edit: 7 years 3 months ago by Sebi.
7 years 3 months ago - 7 years 3 months ago #208411 by Gamer Templates
Sebi wrote: Thank you for your instructions. It works! The only drawback is that the new menue item is not marked as selected.
Gamer Templates wrote: Without changing the cookies it also works :-) If you absolutely want to have it that way. (only ACTIVE does not work)
That's what I said :-)
Instead of custom.css you can also use: Go to Recent Topics -> open -> Link Typ -> Display in Menu -> NO
It is the best way to disable the menu item.
I forgot this option :-)
Delete the css entry and use this way. I change the instruction: HERE
7 years 2 months ago #209643 by Sebi
Thank you again, Gamer Templates.
I tried your second suggestion and it works, too.
But if I click on the Forum > Recent Topics link after, for example, page 3 was selected it will allways get me to page 3.
That is clear because your changes only affect the menu button.
So I implement a redirect in .htaccess from /forum/recent to /forum/recent?start=0.
That works BUT now, if I am logged in and on the forum/recent page (redirected to forum/recent?start=0) I can't log out.
Otherwise, if I am logged out I can't log in.
I know this must be a Joomla issue but maybe someone who reads this can help me with this issue.
Time to create page: 0.269 seconds
