- Thank you received: 2
Question Modal forms are not accessible in Editor
- eSilverStrike
- Junior Member
Have you tested the kunena theme with Bootstrap 3.3.7?
I also tested what I could of some of the possible solutions from here with no result. Does any stand out for you that may be the solution:
stackoverflow.com/questions/10636667/boo...ing-under-background
- Thank you received: 2538
- eSilverStrike
- Junior Member
I have left this fix in for now until a better solution becomes available.
Have you tested the Crypsisb3 template with bootstrap 3.3.7? Does the same issue I am having happen or is something else going on?
I've not tested yet. But the problem exists not only with Kunena, also with others extensions users have problems (see your posted link).Have you tested the Crypsisb3 template with bootstrap 3.3.7?
Why don't you use the suggestion from the iReview-Template-Forum? forum.jreviews.com/topic/29212-bug-irevi...g-issues-with-modal/I have left this fix in for now until a better solution becomes available.
- eSilverStrike
- Junior Member
Modals work in other components like articles, and the JReviews listing editor (their links modal for the editor works).
I rather not fall back to version 3.3.2 unless I really have too. I am fine for right now with the temp fix you provided but would like to see a proper fix in the future when you have time to make the Crpsisb3 template compatible with bootstrap 3.3.7. As far as see the modal problem is the only issue. Did you want me to add this issue to the Kunena GitHub repository?
I appreciate the time you put into Kunena. I know it takes a lot of time (I code a few plugins myself for another CMS)
