Question Modal forms are not accessible in Editor
9 years 6 months ago - 9 years 6 months ago #184174 by eSilverStrike
I am using Kunena 5.0.6.1 the Crypsisb3 template and the latest version of Joomla. My template for Joomla is loading bootstrap 3.3.7
When creating a new topic or replying, if you click on the emoticons icon or link icon on the toolbar the modal form comes up but is disabled and darken like the rest of the page. Nothing is clickable on the page
You can see an example of this by adding a test forum post here .
Does anyone have an idea on how to fix this?
Last edit: 9 years 6 months ago by eSilverStrike.
9 years 6 months ago #184188 by eSilverStrike
Does anyone have any ideas on how to fix this?
9 years 6 months ago - 9 years 6 months ago #184201 by rich
You have enabled Optimize CSS and Optimize JS in your joomla template? I'm not sure if I can see the correct codes.
Please disable both optimizer and test, whether this code works. Add this code in your custom.less. docs.kunena.org/en/manual/backend/templates/edit-less Then empty the cache.
.modal { z-index: 3333 !important; }
Last edit: 9 years 6 months ago by rich.
9 years 6 months ago #184232 by eSilverStrike
Okay I added the code to custom.less and it still happens.
I have disabled the optimizer so you can look into it further.
9 years 6 months ago #184242 by rich
It seems something is not right with your Joomla template (I give up). The modal can't highlighted. You can only push back the elements.
Try this code in your Joomla template custom.css, but it's only a workaround until you have a better solution. Then check in your webpage whether in other sites is all correctly displayed.
.modal-backdrop { z-index: 19; } .modal { background-color: rgba(0, 0, 0, 0.50); } .sidebar-primary { z-index: 19; }
9 years 6 months ago #184246 by eSilverStrike
Thanks your temp fix does work but I have since removed it so the JReviews team can take a look to see what is wrong. If they figure it out I will post the fix here.
Time to create page: 0.323 seconds
