- Thank you received: 2
Question Modal forms are not accessible in Editor
- eSilverStrike
- Junior Member
When creating a new topic or replying, if you click on the emoticons icon or link icon on the toolbar the modal form comes up but is disabled and darken like the rest of the page. Nothing is clickable on the page
You can see an example of this by adding a test forum post here .
Does anyone have an idea on how to fix this?
- eSilverStrike
- Junior Member
- Thank you received: 2545
Please disable both optimizer and test, whether this code works. Add this code in your custom.less. docs.kunena.org/en/manual/backend/templates/edit-less Then empty the cache.
- eSilverStrike
- Junior Member
I have disabled the optimizer so you can look into it further.
Try this code in your Joomla template custom.css, but it's only a workaround until you have a better solution. Then check in your webpage whether in other sites is all correctly displayed.
- eSilverStrike
- Junior Member
