Question How to have label : Question, Solved, Loved, Idea near topic title ???
9 years 1 week ago #185250 by makotosun
It appears not all templates have the option set up. The real question is how do you change a topic from being a question to solved?
8 years 8 months ago - 8 years 8 months ago #194664 by Bouma
810 wrote: same file ;)
Yup. Same file but still cannot change the HTML if you add new labels. And to modify the HTML, it is not so easy anymore since the new paid template blue_eagle5. I just can't find where to change the HTML
<div id="iconset_topic_list"> <input type="radio" id="radio0" name="topic_emoticon" value="0"> <label class="radio inline" for="radio0"><i class="fa fa-file glyphicon-topic fa-2x"></i></label> <input type="radio" id="radio1" name="topic_emoticon" value="1"> <label class="radio inline" for="radio1"><i class="fa fa-exclamation-circle glyphicon-topic fa-2x"></i></label>
This code, I was able to find this using Inspect from Chrome. When I add my own, all working with the xml changes. I really wish I could find where to make the changes.
Last edit: 8 years 8 months ago by Bouma.
8 years 8 months ago #194665 by Bouma
makotosun wrote: It appears not all templates have the option set up. The real question is how do you change a topic from being a question to solved?
You should edit the topic, and click the CHECK topic icon, to change it to solved.
8 years 8 months ago #194672 by rich
Time to create page: 0.264 seconds
