Question How to have label : Question, Solved, Loved, Idea near topic title ???
9 years 7 months ago #179629 by loic
Is there a parameter to check, something to do ?? (i didn't found sorry)
to have the ability to have label : Question, Solved, Loved, Idea... near topic title like in kunena site forum ??
thanks in advance
loïc
9 years 7 months ago #179638 by 810
The option called label , the setting is on the template itself, so you need to click on crypsis
The following user(s) said Thank You: loic
9 years 7 months ago - 9 years 7 months ago #179651 by loic
Thanks a lot for your help
Is there a way to personalized the label text (via language file ?) and images ?
Loïc
Last edit: 9 years 7 months ago by loic.
9 years 7 months ago #179652 by 810
media\kunena\labels\labels.xml
There is the information coming from.
9 years 7 months ago #179661 by loic
thanks you very much
how can i change those icon ?
thanks in advance for your help
Loïc
9 years 7 months ago #179662 by 810
Time to create page: 0.254 seconds
