Solved Running text appears chopped off in right border of text-box
Thank you for the guidance given.
sozzled wrote: Try these ideas:
(1) Unpublish the modules on the right side of the pages where you display the forum
Unpublishishing the module positions on the RHS (3, 6, 8 ) didn't work, as the positions are hard-coded in Beez20.
(2) Disable the plugin options that you do not need, e.g Gravatar integation, uddeIM. Do you want to integrate with Joomla login or Community Builder login; with Joomla access or with CB access? Do you want to use to use Kunena avatars or CB avatars; with Kunena user profiles or CB user profiles? Have you actually installed the Community Builder PM component?
I do not have Gravatar installed. I am planning to install & use UDDIM in the future. I would like to integrate Joomla login with CB login; Joomla access with CB access. I would like to CB avatars and CB user profiles. I haven't installed CB PM component yet, and undecided between UDDE and CB PMS.
(3) Try using Kunena template without the "blend" option?
Would like to know whether you are referring to some flavor of a Kunena template?
Thanks in advance.
After studying the problem of the text not scrolling over to the next line, I made the following observations:
1. Any guest/non-registered member can view the full post, without the text getting chopped off in the right side of the text area.
2. Any registered user too can view the full posts made by other registered forum members.
3. When a registered user posts a message, they are unable to view their own posts in totality after their post is approved and published. The text gets chopped-off/cut-off in the right side of the text area.
4. The user has to hit a CR explicitly in the EDIT mode, and only then they are able to view the text fully.
Your guidance on how to resolve this problem would be appreciated.
TIA.
One additional observation which might be of help:
1. Say a moderator clicks on EDIT TOPIC to rectify the text-chopping problem, but clicks on SUBMIT without taking any action. Then after the post is published, the moderator's own view of that post shows the text to be chopped off. However, when the original user logs in to view their post, they find that their post is now intact, and they can view their post in its entirety.
What inference can be drawn from the above observations? And what is the solution to the problem?
TIA.
Perhaps you have another module published on your forum pages? What happens if you unpublish that module on your forum pages? Does everything work properly then?
I'm guessing, by the way.
solution to your problem is very easy, Kunena Blue Eagle template needs 700px to run without problems. You need to give it that space from your Joomla template. There are too much buttons displayed inline in the post when you log in as moderator or user make a post.
Just unpublish all modules on left or right side of Kunena for Kunena Menu items.
Other solution could be to change Blue Eagle template core files.
