Solved Running text appears chopped off in right border of text-box
14 years 1 month ago #133537 by san65
I am facing this problem of the running text getting chopped off when the user clicks on SUBMIT. Because of this problem, the user has to edit their post, and hit a RETURN before the end of the line is reached.
I tried to tinker with the settings pertaining to text-area width in the Kunena configuration, but no dice.
Any help would be highly appreciated.
TIA.
14 years 1 month ago #133567 by sozzled
It probably has something to do with your Joomla site template. Please read My Joomla site template makes a mess of Kunena
The following user(s) said Thank You: san65
14 years 1 month ago #133672 by san65
Thank you very much for pointing to the right direction: my current Joomla template is Beez 20, and this same problem exists for another site where I am using Beez 20.
I will try to figure out how to resolve this issue, including studying Kunena-compatible templates.
Thanks again...
14 years 1 month ago #133705 by sozzled
Beez20 - if you have not hacked too much of it - is compatible with Kunena. I think it would help better if we saw what it is that you are trying to describe. Can we see your configuration report, please, and a screenshot that illustrates the problem. Thank you.
14 years 1 month ago - 14 years 1 month ago #133725 by san65
Thank you for your response; much appreciated. I am attaching herewith the screenshot of the running text that gets chopped off after the user's post is approved by the moderator. Please observe how you cannot read the lines beyond the textbox-border in the right.
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 64M | Max file upload: 25M
Joomla default template details : beez_20 | author: Angie Radtke | version: 1.7.0 | creationdate: 25 November 2009
Third-party components: CommunityBuilder 1.8.1
Plugins: None
TIA.
Last edit: 14 years 1 month ago by sozzled. Reason: Reveal Kunena configuration report in message
14 years 1 month ago #133730 by sozzled
Try these ideas:
(1) Unpublish the modules on the right side of the pages where you display the forum
(2) Disable the plugin options that you do not need, e.g Gravatar integation, uddeIM. Do you want to integrate with Joomla login or Community Builder login; with Joomla access or with CB access? Do you want to use to use Kunena avatars or CB avatars; with Kunena user profiles or CB user profiles? Have you actually installed the Community Builder PM component?
(3) Try using Kunena template without the "blend" option?
