Question Spacing between Sticky Topics - what determines spacing?
14 years 2 months ago #131687 by sozzled
That could work, too. I will see what happens using those ideas at K.org later. Thanks, snilly. :)
The following user(s) said Thank You: snilloconator
14 years 2 months ago #131688 by sozzled
While the following code (added to the end of your Joomla site template CSS file, do not edit/modify kunena.forum-min.css file) will remove the spacing between sticky topics
#Kunena .kcontenttablespacer { display: none; }
... it also means that if you use Google AdSense to place banner ads in the Kunena module positions , the ads won't appear either. This may not be entirely suitable for those people who want to insert modules into those places.
14 years 2 months ago #131690 by snilloconator
sozzled wrote: That could work, too. I will see what happens using those ideas at K.org later. Thanks, snilly. :)
No problem sozzled. I agree it would be better to add to template.css
14 years 2 months ago #131691 by sozzled
If you meant "it would be better to add it to the template", and you were talking about a "quick-fix" CSS change, then I would disagree that "quick-fix" CSS changes should be applied to kunena.forum-min.css.
If you meant that "it would be better, in the longer term, to redesign the Kunena template so that these things did not happen" then, I agree. It would be better to properly fix such tricky problems as these by redesigning the Kunena template so that these spaces automatically collapsed upon themselves if they weren't being used as place-holders for other modules. For that reason alone, "display: none" is not a very practical solution in the long-run. :)
