Question Spacing between Sticky Topics - what determines spacing?
14 years 3 months ago - 14 years 3 months ago #131553 by GJSchaller
In this example, there's spacing between some of the topics, but not others.
This is a Blue Eagle variant, with CSS applied (but no template changes otherwise, such as to the files themselves).
I can't figure out for the life of me what the difference is. I have a sneaking suspicion it may be related to the fact that I migrated these forums off of SMF, and these posts are different for some reason, but I don't know how / why...
Can anyone enlighten me as to why some are spaced, and some are not?
Thank you!
Geoffrey Schaller
Technical Officer
Knight Realms
Last edit: 14 years 3 months ago by GJSchaller.
14 years 3 months ago #131559 by sozzled
The spacing may have to do with the template module positions . :dry:
14 years 2 months ago #131578 by GJSchaller
Heh, thanks.
I guess my question should be refined as - how does one remove the module positions, or otherwise remove the spacing if no modules are in use? It looks odd that there are gaps without content at random places in the listing.
(Looking for a way to do this without altering the template files - CSS may be the best way, but I am making sure I am not missing something.)
Geoffrey Schaller
Technical Officer
Knight Realms
14 years 2 months ago #131595 by sozzled
GJSchaller wrote: How does one remove the module positions, or otherwise remove the spacing if no modules are in use?
You have to modify the PHP that's used in your template. There's a fairly standard technique in Joomla to create "collapsible" module positions. You can easily find out the answer to that question on the Joomla forum site .
Interestingly, I visited the website (the one linked in your signature) and, using Firefox 14.0.1, I did not see the spacings between the sticky topics in the one forum category that I examined. Have you found the cause and fixed it?
14 years 2 months ago #131680 by GJSchaller
I did, I used display:none on the Div used for the modules. It's a workaround since I don't use advertisements, but it's sloppy for people who may choose to use them in the future, as it will either hide the ads, or leave spaces if those positions are not filled.
Geoffrey Schaller
Technical Officer
Knight Realms
14 years 2 months ago #131683 by snilloconator
Find the following code in your kunena.forum.css also the minified.
#Kunena .kcontenttablespacer { border-bottom: 1px solid; border-left: 0 none; border-right: 0 none; line-height: 0.5em; }
try changing to...
#Kunena .kcontenttablespacer { border-bottom: 1px solid; border-left: 0 none; border-right: 0 none; display: none; }
