Solved Kunena Login module: redirection problem
13 years 9 months ago #140383 by Newkun
sozzled mate, it doesn't work still...I did what you've written but still same.If you need anything please say me, I can supply whatever you need about this problem...but still its login/logout redirection doesn't work
13 years 9 months ago #140390 by Jiminimonka
@Newkun You have not provided your Kunena Configuration Report or a screenshot of your Kunena Login Module settings as per www.kunena.org/forum/K-2-0-Kunena-Login-...ogin?start=30#140164
Please read the FAQ.
Only one question per topic.
13 years 9 months ago #140479 by Newkun
Can you check this please;
kuntest.hostyd.com/
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
Plugins: None
Modules: Kunena Login 2.0.4
13 years 9 months ago #140487 by sozzled
Newkun: Please enable Joomla SEF and setup properly your .htaccess file as shown in Search Engine Optimisation (SEO) . Your login redirection should then work for you. I hope this helps. :)
13 years 9 months ago #140503 by Newkun
Thank you for answer but still same master sozzled
Can you check it again I can give you passwords for the web site...The feature doesn't work...
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Plugins: None
13 years 9 months ago #140538 by sozzled
It looks like this is a defect in the Kunena Login module. We cannot make the redirection work, either. It may be advisable to use the standard Joomla Login module instead.
Reported on GitHub: github.com/Kunena/Kunena-Addons/issues/69
The following user(s) said Thank You: Newkun
Time to create page: 0.170 seconds
