Solved Kunena Login module: redirection problem
14 years 4 months ago #129091 by ppsberlin
I just upgraded from Kunena 1.72 to 2.01.
Now I noticed, that after the login there is no redirection anymore. Tryed some settings to ensure there is no 'old trash' causing this. But it doesn't matter if I set redirection to kunena menu items or to any other menu item of my website.
After login you allways remain at the site you came from.
14 years 4 months ago - 14 years 4 months ago #129094 by sozzled
Configuration report, please. Kunena Login 2.0.1 parameter settings, too. Thank you.
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago #129105 by ppsberlin
Oh yes, here you are:
No matter what is selected as link after login, you stay at the page, you´ve been before login.
14 years 4 months ago #129165 by ppsberlin
Just noticed, that the logoff redirection to home is the same.
Has someone an idea why?
14 years 4 months ago #129672 by ppsberlin
Forgot the config report.
Here we go:
htaccess: Exists | PHP environment: Max execution time: 0 seconds | Max execution memory: 104M | Max file upload: 10M
Joomla default template details : oconcacaf | author: pps | version: 1.3 | creationdate: 2012-05-28
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Third-party components: UddeIM 2.8
Plugins: Content - Kunena Discuss 2.0.1
Modules: Kunena Stats 2.0.1 | Kunena Login 2.0.1
14 years 4 months ago #129806 by xillibit
It could be an issue, i will put it in issue list
Time to create page: 0.152 seconds
