Solved Kunena Login module: redirection problem
13 years 9 months ago #140162 by Newkun
what do masters think of about this subject? xillibit, matias, sozzled, 810? does anyone plan to fix that? or shall we give up?
13 years 9 months ago - 13 years 9 months ago #140164 by sozzled
Newkun: we do not plan to do anything if we do not know what people are talking about. In this topic we have asked for those who have reported this problem to provide us with two things:
(1) their Kunena configuration report; and
(2) a screenshot that shows the settings they are using with the Kunena Login module.
After someone gives us these two pieces of important, vital information, we may be able to better understand the problem and then we can better investigate the answers to these questions.
Last edit: 13 years 9 months ago by sozzled.
13 years 9 months ago #140167 by mwolf
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : jm-0013 | author: joomla-monster.com | version: 1.6 | creationdate: 14/01/2011
Third-party components: UddeIM 2.8
Plugins: Search - Kunena Search 2.0.4 | Content - Kunena Discuss 2.0.4
Modules: Kunena Latest 2.0.4 | Kunena Stats 2.0.4 | Kunena Login 2.0.4 | Kunena Search 2.0.4
Screenshot
As you can see the problem is when you log in redirect do not work, as it should be.
that is the problem, and we would like to open specific category where articles are.
Thank you for all your hard work
13 years 9 months ago - 13 years 9 months ago #140170 by sozzled
Thank you. Now try enabling Joomla SEF rewrite and see if it makes a difference. See Search Engine Optimisation (SEO) in the Wiki for more information. I hope this helps.
Also, disable the setting in the Kunena - Joomla integration plugin that refers to the "login" option.
13 years 9 months ago #140172 by mwolf
then I got 404 page
(yes I renamed htacess.txt to .htacess)
13 years 9 months ago - 13 years 9 months ago #140174 by sozzled
If you got a 404 page, this means that the page you are trying to redirect to has the wrong SEF URL or it means that you have not properly set up SEO n your website. You need to investigate why you cannot use the Joomla SEF rewrite feature if all of your URLs now give you 404 errors.
Time to create page: 0.150 seconds
