- Thank you received: 2
Question Upgrade from K2.0 to K.2.0.1 SQL failed
- NickJWStone
- Junior Member
The forum is working now, except for the old Poll. Didn't test all features at the moment.
Thanks for your quick support!
So there must be a bug if those settings are affecting on shown avatars.
What exactly is happening and when? Can you run a small test for us to track down the issue as I was unable to reproduce it.
- NickJWStone
- Junior Member
I think all the problems started with the upgrade from 1.7.2 to 2.0.0 that was the first time all the avatars were gone. I also started to have some javascript/Mootools conflict I didn't have before (I asked for some help on this forum on that part).
As I was pretty frustrated with these errors and as I was pointed to the standard 'javascript/mootools conflicts' WIKI I decided to do a complete reinstall of joomla, kunena 2.0.0 and all the components/plugins/modules that I used on the site. After this reinstall everything was working, so the conflict on javascript/mootools was from the update and not, as suggested, from the other modules/components/plugins.
I decided to use the 'old' database as I didn't want to loose the forum posts. Everything was working fine, till this next update. After the help of 810 I managed to get this working, although I felt uncomfortable with the database issues. So I decided to remove Kunena and the old database and do a complete reinstall of 2.0.1 and start the forum all over again. So reproduction on the live website is not possible anymore.
If it is of any use I can upload the old database from a back-up in a test environment?
JavaScript issue was coming from a bug we had with the old templates and we later found out that you just needed to change your template after installation in order to fix it. That bug has been fixed since then, so it doesn't affect upgrades from K1.7.
Avatar issue is something that I need to fix -- can you enable integrations one by one if some of the integrations is broken in your environment (ignore gravatars, though)? Just remember to turn off the plugins after test.
What comes to SQL issue, I would love to find a reliable way to reproduce it. So yes, if you were kind enough to setup your backup and play with it a bit, it would be great help for the other users in the future.
How I solved this:
-> Deleted firstly all entries in kunena_poll_users to finish the installation.
-> Took kunena_poll_users from the backup.
-> Use a script which should make the same as
UPDATE #__kunena_polls_users AS a INNER JOIN #__kunena_topics AS t ON t.id=a.pollid LEFT JOIN #__kunena_polls AS p ON p.id=a.pollid SET a.pollid=t.poll_id WHERE t.poll_id>0 AND p.id IS NULL
and convert the table.
My code snippet:
After you have done this, there can be (like on my table) rows which have not been changed, these had a pollid > max(#__kunena_polls.id).
I checked the pollid of this in kunena_topics, but there were no entries. That means, this are entries of deleted topics, so I just used the following query to delete them:
It's a little unprofessional but it should work, hope there is no mistake in my thinking.
Hope it helps you
Yours sincerely
