Question Upgrade from K2.0 to K.2.0.1 SQL failed
14 years 3 months ago #128208 by NickJWStone
Just did that. Install succeful, although all avatars are (once again) gone?
Existing Poll is displayed although voting is not possible (poll doesn't exits, which is logis as I removed all content from database, but why displaying it?)
Thanks for your help sorting this out, I hope everything else is still working.
14 years 3 months ago #128210 by 810
What kind of integration do you use. Cb or jomsocial or only kunena.
14 years 3 months ago #128211 by NickJWStone
Just Kunena, no further integration.
I had massive problems updating from 1.7.2 to 2.0. Ending up in a complete reinstall of the website (fresh joomla, fresh kunena 2.0). But I used the old (updated from 1.7.2 to 2.0.0) database. Was working until this new update.
14 years 3 months ago #128214 by 810
Can you add the kunena report here.
14 years 3 months ago #128216 by NickJWStone
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 512M | Max file upload: 32M
Joomla default template details : rt_clarion | author: RocketTheme, LLC | version: 1.0 | creationdate: February 10, 2012
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Plugins: Content - Kunena Discuss 2.0.1
Modules: Kunena Latest 2.0.1 | Kunena Login 2.0.1
14 years 3 months ago #128218 by 810
I see why avatars dont work. You have enabled. cb and jomsocial plugins.
disable both. then its good again.
Is your forum working now, except polls?
