Question Upgrade from K2.0 to K.2.0.1 SQL failed
14 years 4 months ago #128176 by 810
in the mean time you can make installation to succeed by removing that query from installer
administrator/components/com_kunena/install/kunena.install.upgrade.xml on your site
line 385+ contains this query
14 years 4 months ago #128177 by 810
can you show the data not the table.
14 years 4 months ago - 14 years 4 months ago #128179 by NickJWStone
Sorry, didn't get that:
Kunena Polls seems empty:
SELECT*
FROM`*- _kunena_polls`
LIMIT 0 , 30
Kunena Polls users has the following:
Really appreciating your quick reply!
Last edit: 14 years 4 months ago by NickJWStone.
14 years 4 months ago #128184 by 810
Ok, so polls are messed up. It seems there is no data more. So remove all in Kunena Polls users . Then you can try to update again
14 years 4 months ago #128205 by NickJWStone
Same error after removal:
Query: UPDATE #__kunena_polls_users AS a INNER JOIN #__kunena_topics AS t ON t.id=a.pollid LEFT JOIN #__kunena_polls AS p ON p.id=a.pollid SET a.pollid=t.poll_id WHERE t.poll_id>0 AND p.id IS NULL
14 years 4 months ago #128206 by 810
then remove the tables. and install again.
