Solved Allow only specified users to view/post (private part of forum)
13 years 8 months ago #141847 by Rexi
How can i set access to some subforum (for moderators) for only few ppl.
Moreover, how to be able so only they can see it?
13 years 8 months ago #141852 by sozzled
This is done by changing the permissions for the specific category. Use Joomla ACL, create a user group and assign your moderators to that group, and then define the category permissions so that only members of that user group can view, post new topics or reply to topics as you want.
This is covered, in general, in Simple forum setup instructions
13 years 8 months ago - 13 years 8 months ago #141857 by ClydeTACH
Hi sozzel,
I have a problem regarding this option... I want to have a section and categories in that section visible only to a certain group of users so, I've created a user group in Joomla called "Knights". Then in Kunena I've set a section Access level type to "User Groups" and selected "Knights" in the Primary user Group option and also set the"Primary includes Child Groups" to NO. Then I've tested it with one of my users that is not in the "Knights" user group and he tels me he can see the forum section that is suppose to be hidden. Even categories in that section (that are set to "Knights") he can see the topics.
Am I missing something?!
EDIT: I have Joomla 2.5.9 and Kunena 2.0.4
Last edit: 13 years 8 months ago by ClydeTACH.
13 years 8 months ago #141930 by coder4life
Just curious, even though it is visible can the individual post a topic?
13 years 8 months ago #141953 by sozzled
This is a 30-second tutorial in how to use Joomla ACL to define your users and create a category that only those users can access.
First of all you need to define your user group as a sub-group of the Registered user group. In your case, you want your new group to be called "Knights". This is how the "Knights" user group should be created (as a sub-group of "Registered"):
The next step is to allocate those users to the "Knights" user group, like this:
The final step is to set the permissions on the category so that only members of the "Knights" user group can access. Like this:
That's the general idea. Try it out.
The following user(s) said Thank You: QuakeLive
13 years 8 months ago - 13 years 8 months ago #142024 by QuakeLive
First of all, I apologize - my English is bad but I hope you will understand me.
Is it possible to create a private part (section/categories) of forum, so only users that I allowed can see what's inside and create threads and posts (other users can only see that there is private section/categories - but they cannot see threads, posts... ) ?
Thanks in advance!
Last edit: 13 years 8 months ago by QuakeLive.
