- Thank you received: 2
configuration report
Question Add File not working with Firefox 18+
13 years 10 months ago - 13 years 10 months ago #139318
by senes
Replied by senes on topic Add File not working with Firefox 18+
*** Moved by moderator ***
I want to report an issue, which came out when you use kunena with FireFox 18.
In FF17 everything still works fine, but after upgrading, spoilers don't work any more. Tested on several users.
My javascript console shows the following error:
I am using Kunena 2.0.3, the latest version.
I'm not a JS junkie. Right now, I'm working on a little hack to be able to provide spoilers. Does this issue come out only on my site? Have found nothin about that on the net.
Hope to find some help here.
Kind regards
senes
Kind regards
senes
Last edit: 13 years 10 months ago by Jiminimonka.
The topic has been locked.
- Jiminimonka
- Elite Member
- YBAS!
13 years 10 months ago #139323
by Jiminimonka
Replied by Jiminimonka on topic Add File not working with Firefox 18+
Please provide full information about your Joomla installation, including the version, and other extensions you are using.
13 years 10 months ago #139324
Replied by sozzled on topic Add File not working with Firefox 18+
*** Topics merged ***
senes: I suggest that you very carefully read the last 9 messages posted in this topic before this message.
13 years 10 months ago #139564
by donkey12
Replied by donkey12 on topic Add File not working with Firefox 18+
Hi there,
Since the release of the last versions of Firefox 18.0 and 18.1 the ADD FILE feature of our forums hasn't been working: www.beautyontrial.co.uk/forum/
All keys work with Chrome and Explorer but not with Firefox.
Is anyone having the same problem?
How to resolve this issue?
13 years 10 months ago - 13 years 10 months ago #139573
by Shimei
Replied by Shimei on topic Add File not working with Firefox 18+
There are two things that I have done to rectify this issue. The first one was done awhile back when I updated the mootools.js file located in: /plugins/system/mtupgrade/mootools.js
The issues I had back then, was mainly with profiles not working correctly in various browsers, IE 9 comes to mind.
That file can be found here: Mootools.js.zip
Just replace it with 810's modified file.
The second step was to Add to that mootools.js file in plugins -- system -- mtupgrade:
I had the same issue with Firefox 18 until I made the last change. Now I am running Firefox 18.1. My site, Joomla! 1.5.26 and Kunena 2.04 (with either Tigra or default Blue Eagle) works without error utilizing this combination -- Check out the new Kunena 2.04 -- Blue Eagle and Yoothemes blending here: ReligiousVerse Forum
Hope this helps!
String.prototype.contains = function(string, separator){
return (separator) ? (separator + this + separator).indexOf(separator + string + separator) > -1 : String(this).indexOf(string) > -1;
Hope this helps!
Last edit: 13 years 10 months ago by Shimei.
13 years 10 months ago #139581
by donkey12
Many thanks Shimei,
I am running a Joomla 1.5.26 site with a Gavik template and Kunena 2.0.3.
Hopefully that will be enough to solve the issue.
Time to create page: 0.146 seconds
