configuration report
Question Add File not working with Firefox 18+
13 years 7 months ago #142718
Replied by sozzled on topic Unable to upload attachments (Kunena 2.0.4 with Joomla 1.5)
This could possibly be a Javascript-related issue, given that J! 1.5.26 is hardly "optimised" for the latest browsers. You may find this topic helpful to you
This will be a fairly common condition for those people who are left behind with J! 1.5, I would imagine.
The following user(s) said Thank You: kallle
The topic has been locked.
13 years 7 months ago - 13 years 7 months ago #142737
by kallle
Replied by kallle on topic Unable to upload attachments (Kunena 2.0.4 with Joomla 1.5)
Thank you very much for your hint, sozzled!
Just I've tested the newest versions of: Firefox 20, IE 10, Safari 5.1.7, Google Chrome 26 and Opera 12.
Only the Firefox isn't able to handle the Kunena attachments!
All other browsers have not any problems with the upload-function!
So I think, that Firefox isn't any longer the "great star" under the browsers: While IE slowly is on the way to be better, FF is on the other way.
But -
- there is a simple solution for the Firefox-Kunena-Joomla-1.5-problem:
After installation of the plugin "new_mootools_1.5.1" Firefox is able to upload the attachments too! I'm happy :woohoo:
I understand your opinion of the J! 1.5-version. But I'm not able to force my customer to pay again a lot of money for his very complex website after only 2 years of using on J! 1.5. The change from 1.5 to 2.5 in this special case is the same as to build new the whole site: 4 - 5 weeks of manpower! Besides: For 2.5 there are no follower of a very important component on this site.
So I build a wall of some different security-systems "around J! 1.5" to use it 5 - 6 years. That's the time, I think a customer should be ready to pay some thousands of Euro for a new website again.
Kind regards
kalle
But -
Kind regards
kalle
Last edit: 13 years 7 months ago by kallle.
The following user(s) said Thank You: daviddd
13 years 7 months ago #142743
Replied by sozzled on topic Add File not working with Firefox 18+
*** Topics merged ***
13 years 5 months ago #145035
by daviddd
Replied by daviddd on topic Unable to upload attachments (Kunena 2.0.4 with Joomla 1.5)
Dear Kallle,
I'm in your situation.
J 1.5.26 + Kunena (2.0.2)
The customers won't a system update.
Where did you find the Joomla! plugin "new_mootools_1.5.1"?
When you updated did you have problems?
Thanks!
D
Thanks!
D
13 years 5 months ago #145367
by easycool
Replied by easycool on topic Add File not working with Firefox 18+
Hello everyone,
I confirm this manipulation works even with firefox 21.0, Ubuntu
I recommend to add this code in both files (mootools.js, mootools-uncompressed.js), as it is said in the Shimei post.
thank you
thank you
13 years 4 months ago - 13 years 4 months ago #145903
You should note that the team does not (and will not) test Kunena on J! 1.5 with legacy mode enabled. Please read Legacy mode . This point is reinforced in Do I still need "legacy mode" in J! 1.5? in the FAQs page.
There should be sufficient information in this topic to answer the questions about how to run a J! 1.5.25 website with Firefox 18+
This topic is now closed.
PS: Your message was posted 3 months ago. "As soon as possible" seems to be wishful thinking, perhaps?
As we have now discovered, you are using J! 1.5.26 with the System - Legacy plugin enabled.Mikote wrote: I know that Joomla 1.5.26 is obsolete and I will migrate as soon as possible to Joomla 3.xx, but sometimes it is not possible as fast as I would like.
Last edit: 13 years 4 months ago by sozzled.
