Question Add File not working with Firefox 18+
13 years 7 months ago - 13 years 7 months ago #142205 by dumbterminal
thanx updated the mootools.js as advised in previous posts but didnt work,
added the below code but to no avail with FF 19.0.2
String.prototype.contains = function(string, separator){
return (separator) ? (separator + this + separator).indexOf(separator + string + separator) > -1 : String(this).indexOf(string) > -1;
Last edit: 13 years 7 months ago by dumbterminal.
The topic has been locked.
13 years 7 months ago #142210 by sozzled
Did you also follow the instructions in msg #11 (written by Shimei) in this topic?
13 years 7 months ago - 13 years 7 months ago #142222 by rich
Please try it with this file. On my test page, it works also with Firefox 19.0.2
www.kunena.org/forum/36-German/126364-bi...t-es?start=10#140117
Last edit: 13 years 7 months ago by rich. Reason: link corrected
13 years 7 months ago #142670 by Bob Britt
Shimei wrote: There are two things that I have done to rectify this issue.
Hope this helps!
Sure did, thanks!
13 years 7 months ago #142674 by pendley
thanks pointing out that feature.. that pop up is awesome. is there a way to make mp3s play and preview same way.
13 years 7 months ago - 13 years 7 months ago #142715 by kallle
I've installed Kunena 2.0.4 under Joomla 1.5.26.
Almost all functions are ready. But when I try to upload an attachment (file or image), I get the "Search-Dialog" but after choosing a file and using the OK-Button there is no filename to see in the Attachments-Field.
(Settings to allow upload are made: files up to 10 MB and images up to 2 MB. Right file-extensions are set too.)
Is this a generell problem under Joomla 1.5.26 or what can be the reason? (Same behaviour under installation on webserver or local installation on xampp.
What can I do?
THX and regards
kallle
Last edit: 13 years 7 months ago by kallle.
