Merged Kunena 1.7.2 -> 2.0.0 -> 2.0.1: Empty general statistics in backend
14 years 2 months ago #132349 by xillibit
YannickS wrote: Attached a modified version of the following file:
/administrator/components/com_kunena/libraries/forum/statistics.php
File Attachment:
File Name: statistics.zip
File Size:2.16 KB
Unzip/extract the package and upload the file by FTP
If you disable the statistics in your config, the statistics in your admin panel will be still visible.
Kunena 2.0.1
Cheers B)
Can-you write what has changed in your file ?
14 years 2 months ago #133312 by YannickS
Hello Bill,
I just removed the if-conditions around the output of the statistics. Not sure if it was the best way, but it´s the fastest. ;-)
Feel free to add it to the core if it is working for you guys too.
Best regards,
Yannick
14 years 1 month ago #134446 by skybax
Same problem in K 2.0.2 you can see your stats in the backend just by making them public a thins that is not that grate.
In K 1.7.2 you can disable frontend stats but still see the backend stats.
Can we call this a bug ?
14 years 1 month ago #134475 by xillibit
The behaviour hasn't been right implemented like in K1.7.2, i will try to fix it
The following user(s) said Thank You: skybax, YannickS
14 years 1 week ago #136826 by pilyo
Replied by pilyo on topic kunena 1.7 to 2.x
Can i give a follow up question? i look at the general statistics at the backend. Its empty. its not recording anything now.
14 years 1 week ago #136834 by sozzled
