Merged Kunena 1.7.2 -> 2.0.0 -> 2.0.1: Empty general statistics in backend
14 years 4 months ago #129774 by Bastian
Dear all,
I have following issue:
After update from Kunena 1.7.2 to 2.0 the General statistics in backend is shoing no figures anymore.
After update to 2.1 the same issue still there.
I couldn't find this problem in the knowing issue list and it seems it's not reported in the forum by other users yet.
BR, Bastian
14 years 4 months ago #129801 by xillibit
Do you have tried to recount statistics ?
14 years 3 months ago #131579 by Bastian
Yes, I did. And there appears also the message "Statistic successfull calculated".
But still nothing to see, see attached screeshot.
14 years 3 months ago #131601 by sozzled
Bastian wrote: I couldn't find this problem in the known issue list and it seems it's not reported in the forum by other users yet.
There are no reports of this happening elsewhere. I do not know what has happened in your case. Your case seems to be unique.
In your case, if this is a serious problem to you, I would recommend that you either engage a skilled professional to assist you with debugging the problem or, revert to your previous backup when everything was working the way that it should have.
Please also read the Guide to posting questions when asking for support that appears on the Index page of this forum. Generally your questions will be answered a lot quicker if you comply with the conditions set out in the posting guide. The more information you can give us about your site configuration, the better.
From the sounds of things, you may have a database corruption or a faulty installation of Kunena.
14 years 3 months ago - 14 years 3 months ago #131662 by baxterbln
No sozzled, i dont think its a single problem. I had the same situation after a upgrade from 1.7 to 2.0.1. and i cant find the problem.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 200M
Joomla default template details : jsn_gruve_pro | author: JoomlaShine.com | version: 1.1.0 | creationdate: 07/31/2012
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Third-party components: UddeIM 2.8
Plugins: None
Modules: Kunena Latest 2.0.1 | Kunena Stats 2.0.1
Last edit: 14 years 3 months ago by baxterbln.
14 years 3 months ago #131664 by sozzled
You have turned off "Show stats" in your Kunena configuration.
Time to create page: 0.160 seconds
