- Thank you received: 3
Question Major Problem Saving OR Editing Posts
- freedomcoach
- Premium Member
So far my experimentation has not produced anything definitive but I can say for sure that starting sentences or paragraphs with a contraction like "I'm" will predictably trigger the error message. What do you recommend as the next step?
Howard
freedomcoach wrote: What do you recommend as the next step?
I believe it's necessary to test that hypothesis with the creation of a test site on your webhost in the way I have been advising you to do over the past many months, namely, a site build on a clean version of Joomla, a clean version of Kunena and ... nothing else.sozzled wrote: [My hypothes is that] the problem lies with your webhost ... [and] something that should not be ruled out.
- freedomcoach
- Premium Member
Since it took him considerable time to locate it and fix it, he has requested that his solution not be posted here or given away. I appreciate and respect that.
There has been a similar theme re a template related file in a thread on the preview window.
Back a few months ago, I said these problems are so similar, they may in fact be the same. At the time, I felt like my comment was dismissed. Now it appears that I was right on track.
My consultant has told me that I will need to use this customized file with future versions of Kunena unless at some point the official one resolves this issue by itself.
Anyways, I'm thrilled that this issue is finally resolved and that my users and I can post all the "I'm"s and "Don't"s we like.
What template are we discussing: a Kunena template or a Joomla template? It's important that we understand what we're discussing here. There is no file edit_editor.php installed by Kunena or referenced (as far as I can tell) by K 2.0. This looks to me like a case of My Joomla site template makes a mess of Kunena .freedomcoach wrote: I'm happy to report that my "apostrophe" problem with forum posts has been solved. A highly skilled Joomla consultant tracked it down to the edit_editor.php file connected to one of the templates
I am pleased that you have found a solution but I should like to confirm that the issue has its origins in a choice that you made rather than in a defect in the Kunena software.freedomcoach wrote: My consultant has told me that I will need to use this customized file with future versions of Kunena unless at some point the official one resolves this issue by itself
- freedomcoach
- Premium Member
He did not say there were any bugs in Kunena. He did mention the one Kunena template that he focused on but I don't remember the name. I'll check on this and post it here.
I'm planning to revamp my home page and main site template pretty soon and may also be switching hosting companies because I'm finding that my site has other issues with the host I'm using. So these changes may also impact the editor apostrophe problem too. I'll post developments soon!
Of course it would be wonderful if there was a one-size-fits-all approach but, given the vagaries of Joomla, differences in PHP implementations by different web hosting companies, differences in the webhosting software itself, MySQL, choices that people make and so on and so forth, a one-size-fits-all solution to every situation is unattainable given the limited expertise available within the Kunena team. Not impossible; just not attainable.freedomcoach wrote: I am not making any claim of a fault with Kunena. My consultant said that it was a matter of how the Kunena files interacted with my site that caused the issue.
Good luck with your forward plans.
Although it's difficult to confirm that the problems you've had with losing data when you (and your users) have posted messages on your forum are related to the problems involving "message preview", it may be of some reassurance to note that the team has made steady, overall progress towards resolving many of those "message preview" problems.
You should note that after the release of K 2.0.4 (which addresses several issues we've discussed in this topic) the project does not intend to address any further matters involving K 2.0. This is to allow the team to focus solely on K 3.0.
