Question Major Problem Saving OR Editing Posts
14 years 4 months ago #129212 by freedomcoach
An old problem that I observed occasionally with K1.7.2 has resurfaced. It pertains to the simple process of saving a post and editing a post. Here's an example of my experience.
Today I attempted to reply to a user's post. The Preview only showed a portion of my post. I clicked the preview button a few times but I still saw only a small part of my post.
Then I clicked on submit and only this small part of my post was saved. I then attempted to edit the post and add the remaining text but it would only continue saving that small first segment.
Then after continuing to repeat this process of editing and saving I received the error message:
Cannot save message: Message body is empty!
This same pattern showed up near the very end of K1.7.2. I didn't bother reporting it here because I figured that whatever it was, it would likely get fixed with K2.0. It did go away for a while and now the problem is back.
I tested this to see whether it was specific to one topic but it is not. The pattern showed up in other topics. Yet it was also not consistent. On one occasion when I copied and pasted one sentence over and over into a message I was able to submit it and have it save.
Many of my users are posting substantial messages apparently with no problem but I do recall having at least one user who reported this exact problem with K1.7.2 so it is not only me.
This is obviously a major issue preventing my forum from functioning so I'd appreciate it if a high priority can be placed on getting this figured out.
If this pattern is not showing up anywhere on other installations of Kunena, I'm willing to entertain the possibility that this issue is a result of something specific on my website. I will post my Kunena configuration immediately after this post.
Sincerely,
Howard
14 years 4 months ago #129214 by freedomcoach
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 160M | Max file upload: 40M
Joomla default template details : btc2012 | author: Illiana Technology | version: 1.0 | creationdate: 2012-03-29
Third-party components: CommunityBuilder 1.8.1 | UddeIM 2.8
Plugins: None
14 years 4 months ago #129215 by sozzled
Have you tried me on Skype?
14 years 4 months ago - 14 years 4 months ago #129334 by freedomcoach
Sozzled, I sent you a private message here. Please get back to me as soon as you can. It is important that we speak on Skype.
Last edit: 14 years 4 months ago by freedomcoach.
14 years 4 months ago #129335 by freedomcoach
To Further clarify the issue of posting and saving in this thread, here is a more detailed description of what is happening.
With some specific blocks of text, pasting it into a message box and clicking on preview, I see only the first portion of the message appear.
If I attempt to break it down into smaller segments of text, some portions will appear in the preview window and others will not. Then, when I type the words one by one I reach a point where suddenly the entire preview box goes blank as if the word I typed somehow wiped everything out.
This explains why I sometimes get the error message "Cannot save message: Message body is empty" because Kunena actually believes that it is blank.
I can type many other things and save with no problem. I can even copy/paste a large block of text and save with no problem but for some reason certain specific words or phrases or codes cause Kunena to go crazy.
It is hard to imagine what could cause this to happen. I am in the process of having my Joomla consultant test this himself. If it saves normally in a Kunena message box, then the only logical conclusion would be that there is some issue with my browser interface.
I tried to clean the text to make sure that there were no strange embedded characters and I also tried to remove the color codes but this did not change anything.
I'm naturally open to any other form of troubleshooting on this issue.
14 years 2 months ago #133661 by freedomcoach
For several months now going all the way back to Kunena 1.7.2, I've been plagued with the most frustrating problem when posting a simple text post:
I've done everything imaginable to diagnose the cause including hiring Joomla experts who have devoted dozens of hours trying to resolve this. To no avail. It still exists.
My request here is simple. If there is ANYONE who has experienced this problem and hopefully resolved it, PLEASE tell me what it is or at least help point me to where I might find a solution.
This is totally crazy making for me and my users.
Sincerely,
Howard
Time to create page: 0.157 seconds
