Question Integration Tab Missing
14 years 4 months ago #127901 by mplayer
Replied by mplayer on topic Integration Tab Missing
works great. thx!
14 years 4 months ago - 14 years 4 months ago #127925 by BadCluster
Replied by BadCluster on topic Integration Tab Missing
sozzled wrote: The integration tab in K 2.0 was removed because it was more difficult in Kunena to apply those settings from the Kunena component into other extensions. Instead it was easier in the design of K 2.0 to control the features of other Joomla extensions by writing separate Joomla plugins for those other extensions.
Following these simple steps, the integration is really easy:
www.kunena.org/forum/11-JomSocial/113797...forum-whit-jomsocial
With this source code I've integrated kunena 1.7.X with jomsocial 2.6.X in my site.
Now the sign, gender, website ect ect is perfectly working and integrated with JomSocial!
If I go to modify the data in these forms in JomSocial Profile, their are correctly displayed in Kunena Forum!
If you want test it: www.giocoleria.org (this is my official site, with kunena 1.7.X + JomSocial 2.6.2)
I've try to do the same modification in to the files of kunena 2.0, but because kunena 2.0 have not the "integration feature" it's all futile! and it's not working!
I think you can easily integrate this source code in Kunena 2.0.1 and restore Integration Tab and all people are happy :D
- Another Missing Feature 1: In Administrator backend I'd like have the possibility to choose if show or hide the "online status" in the Topic Viewing. I'd like have the possibility to show or hide in frontend of the forum the image "online/offline"
- Another Missing Feature 2: You have remove tab integration (like you do it in kunena 2.0), ok, but give us an option in administration backend that permit to chose if show or hide the Personal Info Icon in "Viewing Topic" page.
I'm sorry for my english... I don't want show me rude.. it's only problem with the language :D
See you!
Last edit: 14 years 4 months ago by BadCluster.
14 years 4 months ago #128103 by BadCluster
I'd like to have a reply to my solution for the missing integration tab.
I think I give you a good solution or not?
Thank you!
14 years 4 months ago #128651 by Matias
Replied by Matias on topic Integration Tab Missing
Integration has been moved to plugins. If you create a solution for this, I'm happy to include it into Kunena, see:
github.com/Kunena/Kunena-2.0/issues/965
The following user(s) said Thank You: BadCluster
14 years 4 months ago #128753 by BadCluster
I'd like to do it... but I'm not a Developer... I can do something, like reverse enginering, but I've not the capacity to do a plugin that do that!
I'm sorry... :_(
14 years 4 months ago #128766 by Matias
No problem. It will probably be done eventually, but there are currently so many tasks and only limited amount of time for me (I do need to sleep).
