Question Integration Tab Missing
14 years 4 months ago #127324 by mplayer
Latest version of joomla 2.5, latest kunena 2.0 and latest jomsocial 2.6.2. The integration tab in kunena forum config is missing.
14 years 4 months ago #127458 by Nothing
Replied by Nothing on topic Integration Tab Missing
Yeah. Same Problem here...no new posts show up in the activitiy stream
14 years 4 months ago - 14 years 4 months ago #127469 by Mortti
Replied by Mortti on topic Integration Tab Missing
Integrations are now (Kunena 2.0.0) as a plugins...
Extensions -- Extension Manager -- Manage... then Filter and Search by Kunena
screencast.com/t/1yECgFnYR
Moved: Integrations are now plug-ins
Last edit: 14 years 4 months ago by Mortti.
The following user(s) said Thank You: mplayer, Prskavka
14 years 4 months ago - 14 years 4 months ago #127861 by BadCluster
Replied by BadCluster on topic Integration Tab Missing
yeah but with the plugin is missing some personalization like:
Status
Website
Birthday
City
Gender
Sign
Facebook
For me there is a really BIG FAULT!
Now, for example, Gender in the forum is "unknow" and I can't change it!
Last edit: 14 years 4 months ago by BadCluster.
14 years 4 months ago - 14 years 4 months ago #127895 by sozzled
Replied by sozzled on topic Integration Tab Missing
BadCluster wrote: Now, for example, Gender in the forum is "unknown" and I can't change it!
In whose forum is gender unknown (yours or this one at www.kunena.org ) and what is stopping you editing your user profile and changing it?
And, in what way, is the gender = unknown a symptom of the "missing" integration tab.
The integration tab in K 2.0 was removed because it was more difficult in Kunena to apply those settings from the Kunena component into other extensions. Instead it was easier in the design of K 2.0 to control the features of other Joomla extensions by writing separate Joomla plugins for those other extensions.
We do need to find an easier way for users to interact with the new Kunena plugins but, for the time being, the "integration" tab is gone and that's the way things are. There a many new changes in K 2.0.0. We have not had time to write all the explanations about how those features work. As we have consistently written, before you upgrade to K 2.0 on your live production site, make sure you test K 2.0 on a test site so that you understand how things work and what you may need to do.
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago #127898 by Mortti
If @mplayer & @Nothing have still problems... this little video will tell you, how you can find integrations and enable then with 2 click...(From Kunena 2.0.0 to ?)
screencast.com/t/NhFcKHyHr
That my first message might to be too hard understand for someones...?
The following user(s) said Thank You: sozzled, hkymre
