Question Image problems?
14 years 1 month ago #134552 by skybax
Replied by skybax on topic Image problems?
from what i understand you have a problem with [img][/img]
Activate Blue Eagle 2.0 (Kunena Team 2.0.2 2012-09-02 )
post an image the edit the post and tell us what the link looks like.
The topic has been locked.
14 years 1 month ago - 14 years 1 month ago #134564 by sozzled
Replied by sozzled on topic Image problems?
anfieldred wrote: No smilies show up either, indeed there isn't even a option to select them in the replies.
This sounds like the problem is related to a Javascript library issue. Please read msg #1 of Before you post your question, read this first ; your question is answered there.
Last edit: 14 years 1 month ago by sozzled. Reason: URL corrected
14 years 1 month ago #134597 by anfieldred
Replied by anfieldred on topic Image problems?
Thank you.. But I get this error "You do not have permissions to access this page." when trying to access that page.
14 years 1 month ago #134600 by xillibit
Replied by xillibit on topic Image problems?
Some advices :
Try to use the default blue eagle 2.0 template
Enable debug mode in Kunena and Joomla! configuration panel, to see if you can see some errors
14 years 1 month ago - 14 years 1 month ago #134631 by sozzled
anfieldred wrote: I am using the standard kunena menu and my template is compatible.
Your configuration report says otherwise.
sozzled wrote: This is not a defect if you are not using the standard K 2.0 Blue Eagle template. This is not a defect if you are not using the standard Kunena menu. This is not a defect if you have enabled all the Kunena integration plugins and all their options - especially if you don't have the required other software installed. And finally, if you have problems with using Kunena with the particular Kunena template that you have installed, please contact the developer to make sure that the template is compatible with K 2.0.2.
As far as Flickr and Photobucket are concerned, you may want to contact those two services or, alternatively, try posting the "missing images" here in our Playground category.
Did you try posting the "missing images" here?
14 years 1 month ago - 14 years 1 month ago #134664 by ymages
Replied by ymages on topic Image problems?
I've got that kind of error stopping the uplaod (for attachment) in the middle of the process to choose another photo on my computer, I get a blank message and impossible to edit that message or to reply to the post ? i had to go in the database to delete the last message
Last edit: 14 years 1 month ago by ymages.
