Question Image problems?
14 years 1 month ago #133959 by anfieldred
Image problems? was created by anfieldred
I have searched the forum, but not found the answer. My users can not attach any files/images from photobucker or flickr. The image tags appear not to work. Every time a user attempts to post a image using the [img]http://...[/img] they get a blank message.
Here is the forum config:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 96M | Max file upload: 24M
Joomla default template details : dd_redcar_05 | author: www.diablodesign.eu | version: 2.5 | creationdate: 2012-03-27
Kunena default template details : EVOLUTION SLATE - FREE Kunena 1.6 template | author: www.TemplateKunena.com | version: 1.7.2 | creationdate: 2012-08-25
Third-party components: UddeIM 2.8
Plugins: None
Modules: Kunena Latest 2.0.2
Any help would be greatly appreciated.
The topic has been locked.
14 years 1 month ago - 14 years 1 month ago #133960 by sozzled
Replied by sozzled on topic Image problems?
This is not a defect if you are not using the standard K 2.0 Blue Eagle template. This is not a defect if you are not using the standard Kunena menu. This is not a defect if you have enabled all the Kunena integration plugins and all their options - especially if you don't have the required other software installed. And finally, if you have problems with using Kunena with the particular Kunena template that you have installed, please contact the developer to make sure that the template is compatible with K 2.0.2.
As far as Flickr and Photobucket are concerned, you may want to contact those two services or, alternatively, try posting the "missing images" here in our Playground category.
Last edit: 14 years 1 month ago by sozzled. Reason: fixed broken URL
14 years 1 month ago #133962 by anfieldred
Replied by anfieldred on topic Image problems?
So am I missing other required software? I installed the package I downloaded I did not realise I had to install further add ons. I am using the standard kunena menu and my template is compatible.
Your above link for "playground" returns a 404 error.
14 years 1 month ago #133988 by kiwi3685
Replied by kiwi3685 on topic Image problems?
Who told you that?
According to its name it's a Kunena 1.6 template. How is that likely to be compatible with Kunena 2.0.2?
14 years 1 month ago - 14 years 1 month ago #133990 by sozzled
anfieldred wrote: I am using the standard kunena menu and my template is
Your configuration report says otherwise.
anfieldred wrote: Your above link for "playground" returns a 404 error.
I fixed it. Try it again.
14 years 1 month ago #134539 by anfieldred
Even using the Kunena 2.0.2 template I still have the same problem. Any ideas?
No smilies show up either, indeed there isnt even a option to select them in the replies.
Time to create page: 0.210 seconds
