Solved Filenames are been renamed when uploading jpg images in Firefox and Safari
14 years 1 month ago #131065
Replied by sozzled on topic Filenames are been renamed when uploading jpg images in Firefox and Safari
I suggest you look at the video (link is in
The Kunena Menu
in the Wiki) to see how to restore/setup your Kunena menu properly).
I think I've tried my best to explain the way things work and why the apparent "randomness" that you seem to see). We may have to take this issue "offline" and work together on it. If that idea appeals to you, send me a PM and we can take matters further in another way.
- twilliams81
- Junior Member
14 years 1 month ago #131088
by twilliams81
Replied by twilliams81 on topic Filenames are been renamed when uploading jpg images in Firefox and Safari
It's actually not random sozzled. I have found that it only happens when using firefox or safari AND it only affects .jpg files. I haven't tried it in IE so it may or may not happen in that browser. It doesn't happen in chrome unless I try to alter the code that shows in the post when i click insert.
If we upload .png files in either of these browsers the issue doesn't occur.I'm not sure about other file types yet but I know this is happening each time in firefox and safari if the user is uploading a jpg.
14 years 1 month ago #131091
The first message posted in this topic is a .JPG.
I have tested posting .JPG images on two sites (one running J! 1.5 and the other running J! 2.5) and I cannot reproduce this problem.
I'm not saying that the issue doesn't arise, I'm just trying to figure a way to reproduce the symptoms.
- twilliams81
- Junior Member
14 years 1 month ago #131096
by twilliams81
Yes it works correctly on this forum that's why I am perplexed that it doesn't work on ours. If you login at
www.scrapbooknewsandreview.com
and post an image in the forum using firefox or safari you will be able to reproduce it that way.
14 years 1 month ago #131101
We do not register ourselves on other people's websites. If you have a test account, you can post the details here so that only you and the forum moderators will see the details. You can use the confidential BBcode tag like this:
It would be good to get to the source of what's causing this problem.
[confidential]Username:
Password[/confidential]
- twilliams81
- Junior Member
14 years 1 month ago - 14 years 1 month ago #131258
by twilliams81
Thanks. It is
Last edit: 14 years 1 month ago by twilliams81. Reason: edit
Time to create page: 0.238 seconds
