Question SOLVED: stdClass::getThumbAvatar() (ERROR!)
- MasterVision
- Junior Member
you can now close this topic
- johnnydement
- Elite Member
- Thank you received: 5
- MasterVision
- Junior Member
Some technincal adjustments with my modules, No code modifications. I just disabled the module Top Members of JomSocial and it works like a charm.
You came to the right solution. We wrote the jomSocial integration into Kunena. No need for a third party module to do that.
Thank for your patience!
fxstein
Oh ok my fault... it is probably a module for JomSocial in which I set Kunena using the jomsocial profile.
I cannot give you a link where you can download the module because it's a paid module..
But I am wondering why it is working perfectly in this site since the forum profile settings is the same with mine.
Sorry - I am not sure I understand. We run no extra module for the Kunena - JomSocial integration.
fxstein
