Question SOLVED: stdClass::getThumbAvatar() (ERROR!)
17 years 9 months ago #5276 by zaks
I think that Mastervision means that he has set Kunena configuration to use the Jomsocial profiles not that there is a special Kunena/Jonsocial module.
This particular error is experienced if you have the Joomsocial Top Members and the KunenaLatest module enabled on the site. So basically it means that if you have set Kunena to use Jomsocial profiles you cannot make use of these two modules on your site.
I am am not sure why there is such a conflict so if there is anyone who can shed some light on this, it would be appreciated. Is is because of the way the Kunena / JS integration is done that we cannot use these two modules ?
Time to create page: 0.098 seconds
