Question Manage Posts
17 years 5 months ago - 17 years 5 months ago #17151 by sozzled
I think that we can honestly say that Kunena 1.0.10 exposes a number of Javascript vulnerabilities, especially if you are using Community Builder. Are you using Community Builder, Keith? Did you upgrade to K 1.0.10? The upgrade may have caused the problem you've just reported.
I have successfully deleted messages on my K 1.0.10 site and not encountered the Javascript symptoms you're referring to. I never experienced these problems with K 1.0.9.
Last edit: 17 years 5 months ago by sozzled.
17 years 5 months ago #17157 by kschuster
I did not upgrade and I'm using Jom Social.
17 years 5 months ago #17204 by grumblemarc
Probably doesn't matter. Either your current Joomla template or some other published extension is causing the Jscript conflict. I'd start looking at one of the JS ones in your case.
