This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Question Sampledata
3 years 2 months ago #229018 by ghardin
Replied by ghardin on topic Sampledata
Where would I find just the Sample Data plugin by itself?  I tried extracting in from the zip and installing that, but it did nothing.
3 years 2 months ago #229020 by Leen
Replied by Leen on topic Sampledata
if you unzip pkg_kunena_v6.1.3.1_2023-08-21.zip on your PC you will find this plg_sampledata_kunena_v6.1.3.1.zip in folder packages
I have now sent it as an attachment
With kind regards
Leen
3 years 2 months ago #229021 by ghardin
That is what5 I did, but I will try this one.  Thanks!
3 years 2 months ago #229024 by ghardin
I uninstalled the plugin and install the one you provided.  Still does not work.  See attached screen shot  of the plugin install
3 years 2 months ago #229026 by ghardin
also, here is the Kunena dashboard after pkg install and the sample data is visible but clicking on the INSTALL button does nothing.
3 years 2 months ago #229028 by Leen
And if you look at the Joomla Home Dashboard it may also be there with an install button
With kind regards
Leen
