This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Question Sampledata
3 years 2 months ago #229032 by ghardin
Replied by ghardin on topic Sampledata
I did that too.  No button to install sample data anywhere!  I suspect it has something to do with PHP setting, because if you can do it, there has to be something in my servers PHP setting that is the cause.  Could you give me your Joomla System > PHP settings and PHP information?
3 years 2 months ago #229033 by Leen
Replied by Leen on topic Sampledata
I use a reseller package from Vimexx here data php and joomla how the test site is
With kind regards
Leen
3 years 2 months ago - 3 years 2 months ago #229052 by rich
Replied by rich on topic Sampledata
Did you install Kunen according to these instructions? docs.kunena.org/en/basics/installation/installation-k6-x
Last edit: 3 years 2 months ago by rich.
3 years 2 months ago #229057 by ghardin
Yes. 4 times.  Only on the local machine did the sample data load.
3 years 2 months ago #229059 by ghardin
I don't see any glaring difference.  I was on PHP 8.1.27 and I switched to 8.0.27, there are some differences on my host site that I can't change so I don't match exactly.  I will see if any of that makes a difference.
3 years 2 months ago #229083 by ghardin
That link is dead
