This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Solved Xmap - Kunena Plugin problems
13 years 5 months ago #144769 by iseca
Replied by iseca on topic Xmap - Kunena Plugin problems
Hello, I have exactly the same problem but I have discovered that it's related to that Kunena hasn't got a module menu item for it like was in Joomla 1.5, at least in my web; I'm right?
If you create a new menu for Kunena and a module for it, Xmap lists the links fine, but the Kunena menu is much more dificult to have a good display result, so this is inviable.
Well, my questions is that; I have no module for K menu, is this correct?
Thanks!
13 years 5 months ago #144777 by anonymous01
iseca wrote: Hello, I have exactly the same problem but I have discovered that it's related to that Kunena hasn't got a module menu item for it like was in Joomla 1.5, at least in my web; I'm right?
No, this is not true.
Kunena-xmap-plugin does not work in kunena 2.* and kunena 3.*.
I can not promise anything ... but maybe I can help you in your trouble.
Our modifications kunena-xmap-plugin work in kunena 2.0, but do not work in kunena 3. *.
Patience ... Give us a little time, please. If we can do it - I will publish here the announcement of this joyous event.
13 years 5 months ago #144782 by iseca
Thank you smirnov, but I have tried uninstalling Xmap Kunena plugin, deleting folder /plugins/xmap/com_kunena and copying text from your file com_kunena.php to original one, but it doesn't wor for me...
I'm using Kunena 2.0.4
Regards.
13 years 5 months ago #144788 by anonymous01
iseca wrote: ...but I have tried uninstalling Xmap Kunena plugin, deleting folder /plugins/xmap/com_kunena and copying text from your file com_kunena.php to original one...
No, it not is my recommendations on installation of a plug-in.
Try to establish an official plug-in and to replace an original file on modified. It also should work.
13 years 5 months ago #144794 by iseca
I can't achieve it Smirnov...
Please, could you explain me how to do it? I'm almost an advanced user of Joomla and have done similar "hacks" lot of times, but can't do this.
Thank you!
13 years 5 months ago #144815 by anonymous01
iseca wrote: Please, could you explain me how to do it? I'm almost an advanced user of Joomla and have done similar "hacks" lot of times, but can't do this.
For the year, hundreds of people have downloaded this plugin. I'm sure the plugin works without problems ...But kunena v. 2.0.4 already in the past. Old version of the plugin is irrelevant today. Soon will be available for download the xmap-kunena-plugin for kunena 3.0. Wait a moment, please, and we will continue this discussion.
iseca wrote: I'm using Kunena 2.0.4
P.S. Please upgrade to the current version kunena (3.0).
