This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Solved Xmap - Kunena Plugin problems
13 years 2 months ago #148483 by marijone
Hi, everyone! I had the same problem and I fixed it thanks to you. Your information was very useful. Thanks again)
13 years 3 weeks ago #149873 by stumpy_dan
iseca wrote: Hi again!
Now I have updated to 3.0.2 from 2.x, but for me, if Kunena menu is not in first position in component parameters, it doesn't show the forum topics and replies in XML map (In "normal web" map, it does).
Thank you!!
I have the same problem. it does nto show in xml map but does show in normal web map!!.
I am not sure what is meant by "if Kunena menu is not in first position in component parameters" how do you do that?
13 years 1 week ago #150391 by iseca
Replied by iseca on topic Xmap - Kunena Plugin problems
Thank you!!
Hi Stumpy,
If you go to Components - Xmap and edit your map, at right, you see the Menus you have to be shown in Xmap. Drag & Drop the menus to change the ordering and put the Kunena menu in first position.
Hope this helps,
Best regards!
The following user(s) said Thank You: stumpy_dan
12 years 1 month ago #159711 by Gastalver
Nevertheless, thank you very much Smirnov for your effort.
11 years 8 months ago #162603 by emeyer
thank you very much, though I just noticed the same problem, and I am using a split menu on my site, so I cant edit the file. I'm looking at the php and seeing if there is a simple solution.
11 years 8 months ago - 11 years 8 months ago #162604 by emeyer
What I did was replace the getCategoryTree() furnciton from the 2.5 plugin with the one from the 3.0 version and it works fine.
<EDIT> Apologies, I had forgotten I had already edited an earlier version of this plugin five years ago. I added the improvments, and here it is,but note my version only works if there are not forum subcategories and there are menu itmes for each caegory. However, it also improves on the original version by not duplicating forum categories if they exist.
<?php class xmap_com_kunena{ static $profile; static $config; // called before a menu item is printed. We use it to set the proper uniqueid for the item function prepareMenuItem($node, &$params){$link_query = parse_url($node->link); parse_str(html_entity_decode($link_query['query']), $link_vars); $catid = intval(JArrayHelper::getValue($link_vars, 'catid', 0)); $id = intval(JArrayHelper::getValue($link_vars, 'id', 0)); $func = JArrayHelper::getValue($link_vars, 'func', '', ''); if($func = 'showcat' && $catid){ $node->uid = 'com_kunenac'.$catid; $node->expandible = false; } elseif($func = 'view' && $id){ $node->uid = 'com_kunenaf'.$id; $node->expandible = false; } } function getTree($xmap, $parent, &$params){ if($xmap->isNews)return false; if(!xmap_com_kunena::loadKunenaApi())return false; if(!self::$profile){ self::$config = KunenaFactory::getConfig(); self::$profile = KunenaFactory::getUser(); } $user = JFactory::getUser(); $catid = 0; $link_query = parse_url($parent->link); if(!isset($link_query['query']))return; parse_str(html_entity_decode($link_query['query']), $link_vars); $view = JArrayHelper::getValue($link_vars, 'view', ''); $layout = JArrayHelper::getValue($link_vars, 'layout', ''); $catid_link = JArrayHelper::getValue($link_vars, 'catid', 0); if($view == 'category' AND (!$layout OR 'list' == $layout)){ if(!empty($catid_link)){ $link_query = parse_url($parent->link); parse_str(html_entity_decode($link_query['query']), $link_vars); $catid = JArrayHelper::getValue($link_vars, 'catid', 0); }else{ $catid = 0; } // Get ItemID of the main menu entry of the component $component = JComponentHelper::getComponent('com_kunena'); $menus = JApplication::getMenu('site', array()); $items = $menus->getItems('component_id', $component->id); foreach($items as $item){ if(@$item->query['view'] == 'home'){ $parent->id = $item->id; break; } } }else{ return true; } $priority = JArrayHelper::getValue($params, 'cat_priority', $parent->priority); $changefreq = JArrayHelper::getValue($params, 'cat_changefreq', $parent->changefreq); if($priority == '-1')$priority = $parent->priority; if($changefreq == '-1') $changefreq = $parent->changefreq; $params['cat_priority'] = $priority; $params['cat_changefreq'] = $changefreq; $jVersion = new JVersion(); if($jVersion->isCompatible('3.1')) $params['groups'] = implode(',', $user->getAuthorisedViewLevels()); else{ $params['groups'] = implode(',', $user->authorisedLevels()); } $priority = JArrayHelper::getValue($params, 'topic_priority', $parent->priority); $changefreq = JArrayHelper::getValue($params, 'topic_changefreq', $parent->changefreq); if($priority == '-1')$priority = $parent->priority; if($changefreq == '-1')$changefreq = $parent->changefreq; $params['topic_priority'] = $priority; $params['topic_changefreq'] = $changefreq; $ordering = JArrayHelper::getValue($params, 'topics_order', 'ordering'); if(!in_array($ordering, array('id', 'ordering', 'time', 'subject', 'hits'))) $ordering = 'ordering'; $params['topics_order'] = 't.`'.$ordering.'`'; $params['include_pagination'] = ($xmap->view == 'xml'); $params['limit'] = ''; $params['days'] = ''; $limit = JArrayHelper::getValue($params, 'max_topics', ''); if(is_numeric($limit))$params['limit'] = $limit; $days = JArrayHelper::getValue($params, 'max_age', ''); $params['days'] = false; if(is_numeric($days))$params['days'] = ($xmap->now - (intval($days) * 86400)); $params['table_prefix'] = xmap_com_kunena::getTablePrefix(); xmap_com_kunena::getCategoryTree($xmap, $parent, $params, $catid); } function getCategoryTree($xmap, $parent, &$params, $parentCat){ $db = JFactory::getDBO(); $catlink = 'index.php?option=com_kunena&amp;view=category&amp;catid=%s&Itemid=' .$parent->id; $toplink = 'index.php?option=com_kunena&amp;view=topic&amp;catid=%s&amp;id=%s&Itemid=' .$parent->id; $categories = KunenaForumCategoryHelper::getChildren($parentCat); $xmap->changeLevel(1); $topics = KunenaForumTopicHelper::getLatestTopics($parentCat, 0, ($params['limit'] ? (int)$params['limit'] : PHP_INT_MAX), array('starttime', $params['days'])); foreach($topics[1] as $topic){ $node = new stdclass; $node->id = $parent->id; $node->browserNav = $parent->browserNav; $node->uid = 'com_kunenat'.$topic->id; $node->name = $topic->subject; $node->priority = $params['topic_priority']; $node->changefreq = $params['topic_changefreq']; $node->modified = intval($topic->last_post_time); $node->link = sprintf($toplink, $topic->category_id, $topic->id); $node->expandible = false; $node->secure = $parent->secure; $xmap->printNode($node); } $xmap->changeLevel(-1); } private static function loadKunenaApi(){ if(!defined('KUNENA_LOADED')){ jimport('joomla.application.component.helper'); if(!JComponentHelper::isEnabled('com_kunena', true))return false; $kunena_api = JPATH_ADMINISTRATOR.'/components/com_kunena/api.php'; if(!is_file($kunena_api))return false; require_once ($kunena_api); } return true; } function getKunenaMajorVersion(){ static $version; if(!$version){ if(class_exists('KunenaForum'))$version = KunenaForum::versionMajor(); elseif(class_exists('Kunena'))$version = substr(Kunena::version(), 0, 3); } return $version; } function getTablePrefix(){ return '#__kunena'; } }
Last edit: 11 years 8 months ago by emeyer.
