- Thank you received: 1425
Please use other categories for questions about problems that you may be having with your website.
Question Crypsis too hard to read and navigate,
- WolfgangOWL
- Senior Member
In portrait view there is no forum menu at all.
810 wrote: for the portrait view you need to reload the page, because the js is looking at the size. then I will hide, and show the menu. If you reload the page, you should see a correct working menu.
Perhaps using bootstrap responsive classes would be better than JS, or at the least hook the window resize event to fix the layout on orientation change. User mandated refresh is a bit counterintuitive as when browsing from my table I myself on occasion switch orientation depending on what I am looking at or how I am sitting.
Also, I have noticed a bit of an improvement in the white/dead space usage on your forum, but there is still a bit of an option where things seem to run together, the user section of posts seems to be out of line with the post itself.
this possibility still exist ?
thanks for help
