Question Kunena 7.1 Beta 3 Released for Joomla! 5.4.x and 6.x
2 weeks 2 days ago - 2 weeks 2 days ago #235341 by xillibit
On the side of php the new collation added by Mariadb should be supported too by mysqlnd extensions. I have found some changes related to this in Php to fix since Php 8.4.0RC1 :  github.com/php/php-src/commit/e9c5f0504c...5ff65f59b1a99d64a7ae and something related :  jira.mariadb.org/browse/MDEV-32975
It seems now that MariaDB doesn't like mix of collations on tables :  github.com/matomo-org/matomo/issues/22536
Last edit: 2 weeks 2 days ago by xillibit.
2 weeks 2 days ago #235342 by Gindi
I have now repeated both tests using 7.1 BETA4-DEV_2026-09-20, and the result was that the table was not created in the database in either test.
2 weeks 2 days ago - 2 weeks 2 days ago #235343 by xillibit
Which php version are-you using ?
I'am thinking to add a requirement check in case of user is using php 8.3.0 and mariadb 11.5 or above it will advise to update to Php 8.4.0
2 weeks 1 day ago #235361 by Gindi
After experiencing a problem yesterday morning where the ‘#__kunena_notifications_mailsqueue’ table wasn’t loading in B4, although it was working by the evening, I created four new test versions with Kunena 7.0.9 today.
 I then changed the collation in the database for all four versions from utf8mb4_uca1400_ai_ci to utf8mb4_unicode_ci.
 I then cleared the browser cache and restarted the computer.
 After that, I installed BETA versions 1 to 4 in the four test installations, and the “#__kunena_notifications_mailsqueue” table was installed in all four of them.
 However, the database error stating that the table was not installed persists in all four test installations.
 My PHP version is 8.4.24
2 weeks 1 day ago #235362 by Pinkeltje
Still unable to reproduce (PHP 8.4.1)
2 weeks 20 hours ago #235371 by Gindi
I’m not quite sure what you’re trying to say.
 As for the database error, I described it in post #235310 on the first page.
 System/Maintenance/Database/Extensions:Database/Kunena
 WarningThere are tables that are not up to date.
 I get this error in every BETA version.
Time to create page: 0.242 seconds
