Question Kunena 7.1 Beta 3 Released for Joomla! 5.4.x and 6.x
1 month 3 weeks ago #235288 by xillibit
Introduction:
The Kunena team is thrilled to announce the third public...
Introduction:
The Kunena team is thrilled to announce the third public beta release of Kunena 7.1, a native Joomla extension for Joomla! 5.4 and Joomla 6.x. This is a development release and should be only be used for testing; this version is not recommended for live websites at this stage. Kunena 7.0 works on Joomla! 6.0 natively without the needs of compat plugin.
The purpose of this release is to encourage testing by downloading, installing and identifying any problems or shortcomings that people may discover. K 7.1.0 B1 is in testing phase and we are aware that people will discover defects. We encourage you to use the forum to report defects, as soon as they are discovered, so that the development team can work through the problems before the release of K 7.1 as a stable product. Reporting defects does not mean that the problems can or will be fixed. The Kunena team is looking forward to hearing your feedback on how well we have achieved our design goals.
Kunena 7.1 has been designed to work on Joomla! 5.4 and 6.0, the requirements are the followings :
  • Php 8.3.0
  • MariaDb 10.4 or MySQL 8.0.13
  • Bootstrap 5.x
The work done in Kunena 7.1 is mostly to update the code base:
  • Remove deprecated code which are planned to be removed in Joomla! 7.0 (replace triggerEvent)
  • Add a way to store the notifications to be send later with the Kunena task plugin
  • Some improvements on the code to optimise a bit the speed
  • Refactor the queries to use Joomla! database query way
  • Add a new setting to choose to display brithdate or age in the user profile
  • Allow with a plugin (will be available later in subcription page) to add new social in user profile (still on work in progress)
  • Some improvements on SCeditor : add undo plugin and allow to handle some others parameters on inserting an image (thanks to joomod)
Download:
Download K7.1.0 Beta3 here: https://github.com/Kunena/Kunena-Forum/releases/tag/7.1-Beta3
Donations
Any donations are needed for future support.
1 month 3 weeks ago - 1 month 3 weeks ago #235289 by xillibit
The news features detailled :
  • New view in backend to see mails stored to be send later by task plugin :
  • New task plugin to send every 5 minutes the notifications mails stored
  • New task plugin to purge the messages trashed
  • New task plugin to clean the attachments with pending status (it will clean the orphaned attachments in case of user has cancelled his message with attachments in it instead of submit it) :
Last edit: 1 month 3 weeks ago by xillibit.
1 month 2 weeks ago #235308 by Gindi
When installing Kunena 7.1 Beta 3 over Kunena 7.0.9, I get an error message.
Kunena 7.1 Beta 3 is installed and has been working without any errors so far.
1 month 2 weeks ago #235309 by xillibit
Thanks to have tested it, i will take a look in this issue tomorrow
1 month 2 weeks ago #235310 by Gindi
I’ve found another database error:2 Probleme
  • Die Datenbankschemaversion (6.0.0-RC1-DEV) passt nicht zur Manifest-Version (7.1.0-ALPHA1-DEV).
  • Die Tabelle „'jom6_kunena_notifications_mailsqueue('“ existiert nicht. (Von Datei: „7.1.0-ALPHA1-DEV.sql“.)
  • 34 Datenbankänderungen wurden überprüft.
  • 5 Datenbankänderungen hatten keinen Einfluss auf die Struktur der Datenbanktabellen und wurden deshalb übersprungen.
1 month 2 weeks ago #235319 by Gindi
Contrary to my last report, I discovered using phpMyAdmin that the message ““jom6_kunena_notifications_mailsqueue(”” does not exist. (From file: “7.1.0-ALPHA1-DEV.sql”) is incorrect. The table does in fact exist.
 I then deleted the contents of the backup directory and the database, installed the backup using Kunena 7.0.9, and then installed Kunena 7.1 BETA 3.
 The installation error reappeared, as did the two database errors. One of the database errors could be resolved using “repair”, but the missing table could not.
 When I took a closer look at the error message, I noticed that there is an opening bracket after “_mailsqueue(” in the message, which is probably the reason for the error message.
