Important Kunena 1.0.9 & 1.5.0a RELEASED!
17 years 7 months ago #10654 by Lambas
Fatal error: Class 'smile' not found in /home/***/public_html/***/components/com_kunena/template/default/listcat.php on line 231
hey yo!
17 years 7 months ago #10658 by Mr Livered
I see there's no patch for upgrading from 1.0.8 to 1.0.9 - I'm hoping to retain my current template when I upgrade (as I've modified it). Is there any reason why default_ex from 1.0.8 won't still work?
Many thanks.
(also this thread seems to be emerging as a mixture of comments on 1.0.9 and 1.0.5a; maybe it could be split to keep the two discussions separate?)
17 years 7 months ago - 17 years 7 months ago #10661 by Admata
Yes. There is something wrong with "Class 'smile'" and Category view. Recent Discussions works, but when you click Categories it seems to lost all formating and with Default-ex template there is following error:
Fatal error: Class 'smile' not found in ... template/default_ex/listcat.php on line 264
EDIT: My message is for Kunena 1.09
It would be good idea to open new separate threads to both 1.09 and 1.50
Last edit: 17 years 7 months ago by Admata.
17 years 7 months ago #10671 by johnnydement
Many thanks.
1.0.x branch only keeps database, rest of the files are deleted during unistall, and recopied during install. So If you want to keep something, I suggest you to backup first...
In fact I suggest you to backup first even if you don't want to keep nothing ;)
2 separated threads will be done, this is not a bug-typo report thread, this thread is an ANNOUNCEMENT...
17 years 7 months ago #10777 by Mr Livered
So no DB changes, in which case the upgrade could be performed by overwriting the files?
17 years 7 months ago #10795 by johnnydement
no, I mean that when you uninstall K!, your database isn't deleted, and when next version install is done, it gets updated.
That means you don't lose messages, users, configuration,... but the phisical files in your ISP are completely replaced.
If you want to keep your template, just download it via ftp, and reupload once the new version is installed...
