Question Joomla legacy mode and Kunena
14 years 9 months ago #106297 by Matias
You still have something legacy installed into your site. I take a terminal to the server and run "grep VALID_MOS * -r | grep -v _JEXEC" in your Joomla root directory.
If you find lines like this:
defined( '_VALID_MOS' ) or die( 'Restricted access' );
You have found the suspect.. Just note that some components like UddeIM and CB itself may have files that are meant only for J1.0..
The topic has been locked.
14 years 9 months ago #106306 by iLucato
Hi Matias, thanks for your reply.
I don't know what is a terminal server and how to execute it. Will that command replace all the VALID_MOS for JEXEC or just find them?
Well, I found in other way a lot of files with _VALID_MOS. My question is, is that ok to replace all VALID_MOS for _JEXEC or it may be unsafe for security reasons on the site or other problem. By changing it, will be allowed to use J! and K! withouth legacy mode on?
Thanks.
14 years 9 months ago #106405 by Matias
Terminal means usually SSH connection (could be using RSH/telnet or some other protocol as well).
You shouldn't just replace _VALID_MOS, because of that doesn't work either. It just allows you to locate files that were designed to be used with Joomla 1.0.
If the line contains both _VALID_MOS and _JEXEC, it will run in both Joomla 1.0 or 1.5. We are searching for files that do not contain _JEXEC, thus are not working in Joomla 1.5. Those extensions need to be removed (except for CB and UddeIM, which work on both).
I think you have either CB plugin or UddeIM/CB template that doesn't work in Joomla 1.5 Native.
14 years 5 months ago #114733 by sozzled
Wiki article Legacy mode has been updated. This topic is now closed.
