Question Joomla legacy mode and Kunena
15 years 1 month ago #91269 by sozzled
sozzled wrote: If you need help finding old J! 1.0 components, template, languages, plugins or modules, please start a new topic in the Miscellaneous, off-topic and general Joomla category and someone may be able to help you. It would also help if you posted your K 1.6 configuration report with your question.
The topic has been locked.
14 years 9 months ago #104007 by Zylkin
When i disable Legacy plugin i'm getting this error: dirrect acces to this location is not aloved. All components, modules, plugins and template compatibility with joomla 1.5. When i disable kunena component everything works fine, no errors. I use standart kunena template. What's the problem and how fix this?
14 years 9 months ago #104017 by xillibit
What Kunena version are-you using ? Are-you using some Kunena modules/plugins ? If, yes can-you give the versions ?
14 years 9 months ago #104030 by sozzled
I will bet a case of beer that this has nothing to do with Kunena. Any Google search of "Direct access to this location is not allowed" will tell you that you have a Joomla 1.0 extension that you're trying to run on a J! 1.5 website. There are no Joomla extensions written by the Kunena project that will give this kind of error.
The "trick" therefore, is how to find which extension you have that was written for J! 1.0. Msg #9 in this topic contains a short guide to how to detect which extension(s) you have that are not compatible with J! 1.5. One of these days I will update the Wiki article Legacy mode to include this guide.
When you have found an extension that is not compatible with J! 1.0, you need to update it to J! 1.5 or you need to uninstall it. That's the problem, that's what's causing the "Direct Access to this location is not allowed" message, and update/uninistall is the solution.
14 years 9 months ago #104038 by Zylkin
I resolved a problem, blame the CB Plugin.
14 years 8 months ago #106231 by iLucato
Hi Zylkin, I'm facing the same issue. I mean, when I disable Legacy plugin I'm getting also the "direct access to this location is not allowed" error message and as you, I removed all 1.0 components, modules, plugins and template compatibility now are compatible with joomla 1.5.
You said you solved it, I'm using CB too, it's version 1.7. How did you solve it? Would you mind to share the solution?
Time to create page: 0.319 seconds
